Holley Blue vs Holley Black
Hohn, Thank you for the concise summation.
MY VP failure: ( I looked at the internals when rebuilt )
was due to the advance piston binding in the brass cylinder , as I understand
a common problem in 02 pumps....( and I suspect not related to low LP pressure )
But I am sure there are many other failure modes.
Thanks again....
Thanks again....
It would makes sense if the advance piston had bound up, basically removing any timing advance that would cause the clatter (or conversely, just retarding timing a bunch).
The Vp that's on there now seems to be holding up quite well. Dad says it runs great and starts reliably below -20F.
Justin
By the way, I thought I would post to this thread for the archives just how a person can calculate how much fuel they will need in terms of GPH from a supply pump. Here's what you need to know:
-- how much HP you want to build for
-- what the BSFC is at maximum hp (.4 is a good conservative assumption)
-- How much a gallon of diesel weighs (about 6.9# for summer fuel up to 7.2# for winter).
Now BSFC is Brake Specific Fuel Consumption, just a fancy way of saying how many pounds of fuel you burn to make 1hp for one hour. So if you are making 100hp for an hour with a BSFC of .4, then you've used 40 pounds of fuel (divided by 7lb/gal to get gallons, or right around 5.7 gallons for diesel).
So, if you're still with me, let's find out how much diesel in GPH we need for a 500hp Cummins:
500hp X .4 BSFC= 200 # fuel per hour.
200# divided by 7 lb/gal= ~28.6 gallons of summer diesel fuel in one hour
Add 20% for additional measure and you're at almost 35gph even.
So, THIS is why I claim that a 95gph or 150gph pump is way overkill for a CTD. A 500hp Cummins only needs about 35GPH!!
Now, unless you have a way for that big oversized pump to throttle back and turn slower, it's a huge waste of life buying a big oversized pump that won't last as long because it's pumping way harder than it needs to.
You'd get pretty tired if you had to do all your breathing through a straw, eh?
Justin
Justin
Mine had a retro in-tank pump added by the dealer and I'm running both for now. I'm dropping the tank soon to remove the in-tank pump and will then run on only one pump.
I have to say, if you are going to these larger pumps designed to pump gas. You must remove as much restriction as possible. The pump will work itself to death trying to pump diesel thru small lines and restrictive bango bolts. And your pressure gauge will start acting crazy. This is called cavitation. When the pump can no longer pump fuel.
Just a little info. I just added a Holley Red with my in-tank pump. 3/8 line to the fuel filter with AN fittings and a Vulcan braided 1/2 line to the VP. Idle=15psi, cruising=14psi and WOT=11psi. Not bad in my opinion. Yes, if the in-tank pump fails the Holley pump will not pull fuel through the in-tank pump, but even if you didn't have an external pump with the in-tank you're screwed anyway, so what's the difference??
I'm gettin rid of that worthless stock lp as soon as possible and putting in a FASS. The fass has a life of 500k miles. Better filtration. Removes all air from fuel. Plus improves overall performance.
How do you stretch the spring on the holleys.
I just put my holley black in last night, and well It is sweet, i ran braided line from the pump, my pump is mounted on the frame and i just cut my harness off the stocker and hooked it u to it and she runs good.
13 psi at idle and 8-9 floored.
Thinking about stretching the spring a little?
And what is the life out of a holley black
If the lift pump is on the block, you must bypass it. If the lift pump is in the tank, some use both pumps.
Where i have my Holley
My FP before Fuel filter change.
I ran the Holley HP150.. it lasted about 5-6 months.. I thought the Grotor would have been the ticket.... not sure what killed it.. went through a few Carters in the same location.. back to a stock pump... FASS sitting in the shop for the past few months... I'll get to it one day....
Bryan
Bryan
AlCorr
114
02-11-2009 02:32 AM
DaNuGuy
23
07-11-2004 10:31 PM
