holley blue and stock lift pump?
Old 12-01-2009 | 05:24 PM
77machomopar's Avatar
I read somewhere that someone was running a holley blue and stock lp on the same line. with the holley pushing fuel to the stock pump. Does anyone know if that'll work. I am asking cause my stock lp was put on in september and i got a holley pump collecting dust on the shelf, right next to the 1/2'' fuel line for it.
Old 12-01-2009 | 05:37 PM
high bid's Avatar
I've been running it this way for almost 2 years. 16psi of fuel @ idle and 14WOT.
Old 12-01-2009 | 06:34 PM
Mike D's Avatar
I run the holly blue and stock lift pump too. It's going on 5 years now with no failures. The trick is to wire the holly off a relay using the power wire on the lift pump harness as a trigger for the relay, that way both pumps will respond to the ECM.
Old 12-01-2009 | 09:44 PM
Cool are you guys using a drawstraw or just stock pick up? Should i use the 1/2 line that i have also or 3/8?
Old 12-01-2009 | 10:16 PM
Mike D's Avatar
I used 3/8 line to the stock pickup.
Old 12-02-2009 | 08:53 AM
high bid's Avatar
Yep stock fuel line. I also removed the banjo bolts from the fuel filter to the VP and drilled the holes out for added fuel flow volume.
AlCorr
114
02-11-2009 03:32 AM
JME07Vegas
50
02-16-2008 11:04 AM
Texaschevelle
26
11-16-2007 09:08 PM
blackdiesel
07-29-2006 04:08 PM
Cumminsdieselboy
13
03-08-2005 09:58 AM
