Holley Blue Question
bamadzl
What kind of feul gauge do you have ? is it electric or mecanical ? if it is electronic check all of your connections.If you keep having problems with it put you a tee in the discharge line at the pump and put a temparary gauge in to make shure it is correct You can also do like I do and put one on top of your feul filter.That way I can check preasure pre filter and post filter.
Originally Posted by BigBlue
That's the only problem I seem to have with holley's. The pressure spring sticks and it causes low pressure. Take some emery paper or very fine sand paper and LIGHTLY sand the plunger and bore and reinstall everything. Works everytime for me.
It appears that the pressure jumping around was a result of my wiring not making solid connection. I had "temporarily" spliced the two wires until I could do it during daylight. Saturday the fuel pressure gauge went to zero and I quickly pulled into a parking lot to fix it. Once I got home I made a good connection and (hopefully) weatherproofed it. All looks good now.
Any idea where I can buy the bypass blockoff??
By the way, thanks a ton for all the input.
Brad
Brad
I did not intall the regulator. I am not running the stock lift pump at all, just the Holley Blue on the frame.
When I first installed it, I was getting a constant 11 psi @ idle and 8 psi @ WOT.
I then stretched the spring in the pump which controlls the internal pressure regulation in the pump. I'm now getting about 16 @ idle and 12 @ WOT.
I'm going to look into blocking off the internal bypass as CTD NUT suggested.
Brad
Brad
Registered
when i first installed mine, it pegged my 15 psi guage and i could only bring it down to 13. during the first few weeks, the needle was smooth and moved slowly, like it should.
now, when i get on it the guage makes a lot of noise and jumps from 15 to 10 psi very very fast. How do i fix this? its driving me up the wall. has anybody else had this problem?
I will add that my pressure will jump around violently for the first few minutes after cranking. After that it calms down and doesn't move unless I give it throttle.
Brad
Brad
At it again
This morning my fuel pressure started jumping around again. It did it for my entire commute. It drives me nuts when it does this. I just can't stop looking at the gauge
. CTD NUT had said earlier that Holley carried a block off kit for the internal regulator. The attached link is holley's fuel pump catalog. There are service parts/kits at the end. Can anyone help me find the kit that CTD NUT was talking about?
http://www.holley.com/data/Catalogs/Fuel%20Pumps.pdf
Thanks
Brad
![Crazy!](https://www.dieseltruckresource.com/forums/images/smilies/crazy.gif)
Thanks
Brad
I will re-check the clamps before I leave work.
But..it was giving nice, steady pressure for about two weeks after I stretched the spring a little. I really think the spring and/or plunger is getting stuck. The pressure is jumping from about 13 to 20 psi. When it was running steady is was 16 @ idle and 12 @ WOT
I'm afraid it's going to damage my fuel pressure gauge. The needle jumps so hard that you can hear it.
Brad
Brad
AlCorr
114
02-11-2009 02:32 AM
Texaschevelle
26
11-16-2007 08:08 PM
RockRover
04-02-2005 08:48 PM
