Holley Blue pump
Re:Holley Blue pump
According to the Holley website:<br> Low pressure pumps that are perfect for NOS wet system pump <br> New tumble polished billet look <br> New lower housing casting for enhanced fuel flow <br> Improved design for street/strip applications <br> Distinctive "BLUE" logo <br> Flows 110 GPH (free flow) <br> Flows 70 GPH at 9 PSI <br> Pressure is pre-set at 14 PSI <br> Includes P/N 12-803 fuel pressure regulator <br> Motor draws only 3 Amps current <br> 7-1/2 Amp fuse recommended <br> Provides constant fuel flow with no pulsation <br> Has externally accessible pressure relief valve <br> Rotor/Vane pump design is more tolerant of contaminated fuels <br> Weighs only 3 lbs. <br> Includes mounting bracket <br> Repair kits are readily available <br> Can be serviced from either pump end or brush cap end <br> NOT compatible with alcohol or methanol fuels <br> Use of safety shut-off switch, P/N 12-810, strongly recommended <br> Not designed or recommended for use with fuel injection systems <br><br>I have used these on alot of 500HP Mustangs that I have built and have never really had a problem feeding them. What are the specs for the stock lifter pump? I would think it would work fine for a booster, but not sure on a replacement. What do y'all think?
Re:Holley Blue pump
Well what I think they mean is they won't work on gasser EFI. The EFI systems on a gasser are in the 40-50 psi range where ours is in the 10-15 psi range. I think that you could just run it without the regulator since it is internally regulated for 14 psi and that should be fine for us. What do you guys think? These pumps can be had for around $100.
Re:Holley Blue pump
I don't understand why everyone wants to have a pusher that goes to the lift pump? Why not just get a pusher that will have the right psi and flow and go to the injection pump, eliminate the problem pump instead of adding to it. Just MHO. ???
Re:Holley Blue pump
(I havent checked my pressure yet ---I'm gonna!)<br><br>As I understand it ? The lift pump seems to fail quickly on some units. <br>Because it is (sucking) fuel from the tank? Is it a rotary vane pump? Is it experiancing cavitation? Has any body pulled a bad one apart to see what is causing the failures?<br> I have a 12 v. AC fuel pump on the shelf, leftover from a previous project . It states,* do not mount over 24 in from the bottom of the tank, and mount as CLOSE to the tank as possible.* It is only 3 & 1/2 lb pressure, but as a pusher to the primary, would it"s extra pressure , perhaps? help forstall the failure of the lift pump . OR - should I remove lift pump and just mount it back by the tank?? <br> I know from experiance that if there is much restriction in the suction line for a pump, it undergoes cavitation and leads to early failure. and (this Dodgeup) / hookup , reeks of some of the installations I have seen on equipment over the years.<br> I HATE Plastic lines . It looks like there are some down there.
Re:Holley Blue pump
Does anyone know what the fuel delivery requirements are for the injection pump? I would love to REPLACE the junk lift pump but I can't find the specs of the stock pump? Am I looking in the wrong places? Is this HIGHLY guarded info? I would think that a Holley blue or black would provide enough fuel for a moderately modified truck...say up to 500 HP.
Guest
Posts: n/a
Re:Holley Blue pump
For a very good discussion of this subject look here (a thread on another forum. Be sure and read what Rod Snaith of Wildcat says).
Summary of the thread:
Most lift pumps fail when the internal regulator goes. The regulator fails because of excessive back pressure in the run between the lift pump and the VP44. The long draw from the tank is only a secondary reason for failure. A secondary "pusher" pump at the tank may stress the lift pump occasionally by pushing fuel that the VP44 on the other side will not accept. What's needed to replace the stock Carter lift pump is a high volume (better than 75 gph), low pressure unit that does not have an internal regulator and will allow the VP44 to do all of the regulating, including bypass and fuel return.
Rod says the Holley Black seems to fit best, and he's considering adding it to Wildcat's inventory. You may want to ask him -- he's Push Rod on this forum. Hope that helps.
Finally, high-flow banjo bolts make a BIG difference in lift pump survivability, whatever the pump/pumps you're using.
GP
GP
Re:Holley Blue pump
Alright. I've had enough of this crappy lift pump. Mines got 785 miles exactly on it and it has dropped from 13.6 at idle to 11.6. WOT went from 6.6 to 3.4. This is with the high flow bolts installed and a new filter (it's also got 785 miles on it). ALL of them. And there are no leaks anywhere. So, what I'm reading here is to replace the stock pump with a Holley Black and to mount that pump back by the tank. Correct? That should completely eliminate any problem with the fuel supply on these trucks, right? How about replacing the fuel line with some 3/8" inside dia. to help flow even more? I figure that if I'm going to be there replacing stuff, I might as well get it set up now for when I get ready to hit 12's. Who carries these pumps and all of the neccesary hardware (instructions, wiring, connectors) to install it? How hard is it to install?
Re:Holley Blue pump
I have been useing the Holley 815 (black) for 18 months now and it was used when I put it on. It's mounted back @ the tank and I run -AN6 lines all the way to the VP44. <br><br>Dean
Re:Holley Blue pump
[quote author=WeirCummin link=board=5;threadid=6416;start=0#60938 date=1036236870]<br>I have been useing the Holley 815 (black) for 18 months now and it was used when I put it on. It's mounted back @ the tank and I run -AN6 lines all the way to the VP44. <br><br>Dean<br>[/quote] <br><br><br> Good info Dean, Welcome to the site.<br> ~chuck.
