Holley Blue Dead at 10k miles
#31
qwest: the Walbros are OEM in many Ford diesel applications. They are fine for the seals.
The Aeromotive pumps are kick butt imo. The Marine version is the one to get-- it's diesel rated. Although I know of many "gasser" aeromotive pumps doing just fine on diesel.
Chris Sutton is going on 5 years on his Aeromotive A1000 setup last I heard-- no hiccups.
A/M is top notch.
...and top dollar
A/M is top notch.
...and top dollar
#32
Just FYI, I e-mailed Aeromotive awhile back about the 11203 pump. They said it would work fine with ULSD, but not Biodiesel. I run B2, so I didn't go with that pump. I'm kinda wonderin if B2 would be enough to affect it though?
#33
#34
This is the one everybody is running. Places like glacier diesel sell kits, but you can get most of the stuff for a fraction of the cost at other places (such as hardware and auto parts stores). That is if you want to take the time to do it. You'll need a regulator, a return line to the tank, and a wired relay to run it. I already had a 'big line kit' I ran with the holley, and I'm rigging my own relay and return. The pump and regulator I bought.
I'll have under $200 in my 'kit'.
Brad
#35
Thanks guys, need encourgement at this time...
Since I have the return line, regulator and relay already installed the only
Item I need is selecting a good reasonable priced pump.
The Item I am missing is a check valve, I want to install 1 in parrallel with
the LP, 70 bucks seems expensive ( best found so far )
My thought is : if the LP dies for any reason, ( pump, relay, wiring etc )
The engine QUITS RUNNING ( that is with a restrictive LP which I believe most of the suction type are ). This is not an option for me.
I have had engine quit on another brand truck. BIG TIME SCARE
Steep mountain,sharp turns, downhill,no shoulder:
Only thing saved me was I was turning away from the shoulder, if not
would have gone over the side....
So, that is a requirenment ( engine continue to run with LP failure )
and easily replaced spare ( lot's of 'slightly used ' LP's in stock..
AlCorr
114
02-11-2009 03:32 AM
Texaschevelle
26
11-16-2007 09:08 PM
wizkid
07-08-2004 01:11 PM
