holley blue
I'd run the Holley blue from a relais. You'll need a battery source (fused) and put the hot wire from the vulcan extension to the coil side of the relais, other coil post to ground, switched post to the holley. I had the holley running off the ECM for a short time but the pump made some electrical noise that the ECM didn't like too much (ran like ****)
HTH
AlpineRAM
HTH
AlpineRAM
AlCorr
114
02-11-2009 03:32 AM
Texaschevelle
26
11-16-2007 09:08 PM
