Holes in my air box ????
2001 ram with stock air box.<br>Box has K&N But is it enough air ( me thinks not!!! )<br>I work in the dessert. About 50 miles a day off road.<br>Fine talc type sand. So fine I can't keep it out of anything ><br>This has kept me from going to the open style air filter.<br>So the same applies to holes in the air box.<br>OK <br>WAIT<br>WAIT<br>WAIT<br>WAIT<br>Now let me have it , I asked for it ;D
Re:Holes in my air box ????
I think that if you want to stay with the stock airbox you better make real shure that the filter sits correct and seals. On my truck the airbox did not seal too good with the stock filter. I switched to the BHAF and have less dirt in the air intake than with the stock box.<br>I don't know about the K&N, never used one on the RAM. <br><br>Maybe you should look into the scotty system, it looks like a good sealing unit to me if you are comfortable with oiled filters. <br><br>AlpineRAM
Guest
Posts: n/a
The stock airbox will probably be fine as long as it's not really "pushed", such as heavy towing in steep grades at high boost levels - otherwise, you will get significantly better flow if you drill the box - the stock air entry by itself is pretty restrictive under maximum engine demand...
Ok I figgured what could a few small holes in the bottom of my air box hurt ;D<br>Well I can answer that now <br>First hole went fine,,,,,,,, Second hole ok,,,,,,,,,Third hole,,,,,<br>Bang out came 1/3 of the bottom :'( :'( :'(<br>I guess this makes it easy......SCOTTY<br>**** I hate it when I screw up lice that > > >
snow, Mine did that as well :'(
I just left it untill I got the Dam-air system from Air Bulldog. It is a cold air intake from a front lower spoiler. there is a piece to modify your stock airbox and I used plastic and glue to seal up the holes I did in the bottom. I still use the stock opening in the fender but I used some foam to seal out the hot temps of the hood so only cool air from the front of the truck comes in. you can see the grille intake on the spoiler in the center of it. there is a 5" tube that goes from that to the airbox.
This is the back of my truck, it has a bedrug, lights stereo, Aux Batt for the lights and a 12 vlt heater. have recovery equip. as well.
1969mach1
04-05-2007 07:47 PM
1stTimeAround
07-05-2006 12:30 PM
vctowpig
07-08-2005 10:40 PM
Dodgezilla
21
02-03-2004 04:26 PM
