HO & SO Pump 6spd
Old 10-04-2007 | 06:49 AM
Thedieselkid's Avatar
HO & SO Pump 6spd
I am wondering if every 6spd truck is and HO? If not how can I tell the difference? I am looking into buying a 2001 or 2002 ram 2500 and would like to have the SO pump, but a 6spd as well.
Thanks,
Paul
Old 10-04-2007 | 08:16 AM
blackdiesel's Avatar
Registered
All 6 speeds in 01-02 will be HO's, all 99-00 with 6 speeds will be SO's. Go ahad and get the HO, it won't be to long before you have to replace it, then you can get a SO pump.
Old 10-04-2007 | 10:39 AM
stuckey200224's Avatar
just remember the 99-00 6 speeds have the 1-1/4 input shaft like the 5 speed.
Old 10-04-2007 | 04:15 PM
so would you get the SO truck with a 1.25 shaft and upgrade it, or a HO and replace the HO pump with and SO?
Old 10-04-2007 | 05:51 PM
Registered
You will be replacing the pump on eather truck sooner or later. so get the 01-02. You probley can't fine a 99-00 with a 6speed if you wanted too. (rare as hens teeth) You won't need the SO pump till you get up to around the 500 mark anyway.
westport
11-24-2005 02:43 AM
norsk
07-19-2005 09:26 PM
BAMFT
11-17-2004 02:27 PM
dieseljerk
11-12-2004 11:12 AM
Steve10
03-04-2004 10:56 AM
