highest EGT*
#47
Originally Posted by linetrash75
I agree with Hohn the smarty may be a better choice for towing, for the simple fact you can add pressure and duration,but no timming.
Jed
Jed
Vp trucks can only manipulate injection pressure curve with fueling boxes and injector size.
#48
Originally Posted by herb
Just got the 01 back from the body shop. It fell thru a drain pit cover at our local car wash (replaced front bumper and repainted both front fenders.)
drove it home (15 miles with 0 fuel pressure , this is the new one that was put on when engine was rebuilt 4500 miiles ago)
Ordering a fass tommorrow.
Guess i will pull the edge but know i will be staved for power pulling the gooseneck.
Just returned from a trip with the 03 and the 46' gooseneck . went to Branson, Jasper and Liberty Hill Tx back thru Memphis and picked up a load of trailers ( 2 car haulers and 4 16' utilitys ) and the 03 pulls great with no problems except for the 9 mpg.
Called Extreme Deisel today to order a Fass pump and they talked me out of it. Said they are pulling the Fass from their website because the are having to many problems with them.
suggested, and sold me
BD-Power Dodge Lift Pump Kit (OEM Bypass)
2000-2002
Part#: BD1050229
(Qty: 1 x $232.75)
Claim these pumps are more reliable.
Any input---first hand knowledge ?
#50
2000-2002
Part#: BD1050229
(Qty: 1 x $232.75)
2000-2002
Part#: BD1050229
(Qty: 1 x $232.75)
My personal favorite pump is the Walbro 392 used with a good bypass pressure regulator. Walbros last several hundred thousand miles on Power Stokes.
#51
thats what they said. the BD is a carter that is built like the OEM should have been. Was suprised Extreme downgrading fass with all the praise i have heard of it on this forum.
#52
I read alot about the lift pump problems , and knew i had to do something after adding INJ and boxes so i found a site that done a mod that really makes sence . The pump that cummins uses should b gravity feed , the pumps now are working as a puller and a pusher , they cant handle that , heres what i done
I use a holley volumax 160 GPH pump and a fuel/air seperator 5 micron filter
1/2 in lines to the Vp 44 , i trashed the factory lift and filter assembly , this has been on for 6 months with noo probs i hold 22 psi with no regulator I did have to route a line from the pump to the supply side of the tank cause i did peg a 30 psi guage when first installed , I have about 200$ in this setup
#53
Originally Posted by Rods
i peg 1600 deg in 1 sec with smarty/ 7x10s and hx35 with a 16 cm housing 35+ lbs boost ,normal driving is 1000
#55
installed the BD today and still have 5 lbs pressure. took gauge out of truck and checked at the pump --still 5-- have a issappo gauge --do these gauges ever go bad ??
#58
The Guru
My Fass has been as good as the day that it went in. I still have 16psi at idle and 13 psi at wot. I wouldn't hestate to recommend it to anyone. I have about 100000 miles on it, before that I used up three cummins LP's. So I'm saving money.
#59
Called Extreme Deisel to order a Fass pump and they talked me out of it. Said they are pulling the Fass from their website because the are having to many problems with them.
2000-2002
Part#: BD1050229
(Qty: 1 x $232.75)
