Higher EGTs w/ HRVP44?
Cruising, I've noticed no increase in EGT. And looking at the fuel you're pushing, I'd imagine you can peg the pyro already, so the HRVP might just get you there a little sooner.
I can hit 1500 quickly, and I am not fueling as hard as you are. If your VP is not dead, I would look for another turbo before upgrading the VP. Just my $.02. HTH.
If you need a replacement vp then the hrvp should make your other bombs work better by providing more fuel throughout the rpm range, but hrvp or so vp44 both seem to top out around 600 hp without drugs.
That is my problem. I can get used 200+ dynomite sticks right now for a great price from a buddy and get a normal VP. What mods would be needed for 600hp without a HRVP44?
Comp + mach 6 + the right turbo(s) = 600 hp
Either you're looking at a 66 turbo or twins.
The only person I know of on this board running 600+ on a single turbo 2nd gen is Jetpilot with his steriod b-1: he'll make some good recomendations
http://www.performancedieselwarehouse.com/
Mark03Ram
09-25-2007 08:27 PM
06Cummins
01-09-2007 03:55 PM
XLR8R
11-30-2006 10:25 AM
omaharam
10-19-2006 10:33 AM
