high idle srew on p-pump??
high idle screw on p-pump??
okay so there is this screw on my pump that stops the throttle lever from going all the way, can i just remove that screw, and will it allow more throttle?? thanks
jason
jason
yah i have enough fuel already, but i was just curious about the throttle stop, since i used to have a first gen motor and they had stops that kept the throttle from going all the way, i was just wondering if these pumps had the same thing, and i do plan on twins once i break in the motor and trans, gosh i hate waiting thanks for the responses
jason
jason
Not really.. Even the governor arm system is on a spring loaded rail. If the governor has enough jam, it can override the fuel plate, just like not having one. Removing the screw doesn't have the same effect as adding a GSK. For the money, the GSK is a better bet. With the new springs, the entire RPM band is improved for response instead of just longer pedal travel..
jmccart
06-12-2007 02:12 PM
dieselnewbie
01-18-2005 10:48 PM
