High Idle??
High Idle??
I have a Smarty for my truck and keep it set on level 9.. There have ben numerous days where its been below freezing in the 20's and teens sometimes even.. The high idle feature hasn't kicked on at all yet except one time. When is it supposed to?
I am not sure at what temps but mine kicks in every morning. Sometimes it is a high idle. And then when it gets really cold it cuts to the three cylinder idle.
Sounds like the truck is going to come apart. My neighbors dont like me in the morning but nothing i can do.
It was in the high 20's here for a couple of days in January and mine went to high idle twice. You didn't push the clutch or the brake in again after you started it or touch the accelerator did you? From what I know, that will turn the function off.
same goes for the smarty high idle same as the dodge specs, it just turns it on. you have to rember that the intake temp is taken After the Grid heater, so after the two toaster dual toaster ovens. but ya . for mine to kick in the temp out side has to below 5 degrees for mine . and the truck has to be ice cold. and not been pluged in.
Once enabled, idle speed will slowly ramp up from 800 rpm to 1200 rpm when all of the following conditions are met:
1. Intake Manifold Temperature less than 0°C (32°F) and,
2. Coolant Temp is less than 60°C (140°F) and,
3. The Transmission is in Neutral or Park and,
4. The Service Brake pedal is not depressed and,
5. Throttle = 0% and,
6. Vehicle Speed = 0 mph
Additionally, if Intake Manifold Temperature (IMT) is less than -9°C (15°F), and all of the parameters above are met, three of the cylinders will be shut off upon reaching 1200 rpm, creating a slight change (yea right!) in engine sound which is normal. This allows the engine to create increased heat in the cooling system, allowing more rapid engine warm up and cab heating.
Both features will automatically disable when one of the following occurs:
1. The Automatic Transmission is placed in gear (forward or reverse) or,
2. The Service Brake pedal is depressed or,
3. Throttle position is greater than 0% or,
4. Vehicle Speed is greater than 0 mph or,
5. Coolant Temperature is greater than 79°C (175°F).
Engine speed will return to normal operation at 800 rpm. If the engine continues to idle and coolant temperature is at or below 60°C (140°'F), the feature will reenable. In order to operate properly, the Accelerator Pedal Position Sensor (APPS) must stay at idle.
jmccart
06-12-2007 02:12 PM
dieselnewbie
01-18-2005 10:48 PM
