high idle
Old 12-10-2006, 11:54 AM
Marine's Avatar
I am surprised it was that dirty. Usually only trucks with exhaust brakes get dirty.
Old 12-10-2006, 12:18 PM
bnold's Avatar
I’m surprised no one has figured a way to trick the IAT into thinking it is colder so high idle could be used above 15*
Old 12-11-2006, 08:34 AM
getblown5.9's Avatar
some people have figured out how to do that...but it involves the proper resistor and a way to switch it on and off.
Old 12-11-2006, 09:36 AM
bnold's Avatar
Hmmmm... Resistor mods always scrare me
Old 12-11-2006, 12:36 PM
b4wheeler's Avatar
I still think my idea from Saturday night is best.
Remove the IAT, plug the hole, relocate the IAT to the actual air intake path.
Someone try this and let me know what happens....
I don't have mine bombed enough for it to make a difference.
P.S. With all the mods getblown5.9 has done to his truck and the amount of soot it blows. I would not doubt the IAT was that black.
Old 12-11-2006, 01:05 PM
1-5-3-6-2-4's Avatar
I had 3 cyl cut out come on last week here when we dipped into the -30c. I forgot to plug in one night anyways, go out to startup at 0515 @ -30c the truck fires but its bucking like a wild horse..............60 seconds ramp-up begins. still burping and farting at 1200rpm them BAM it smooths right out when it dropped the 3 holes.......heated right up, well after 15 minutes it defrosted the windshield.
I love it
Old 12-11-2006, 01:19 PM
the soot blowing exhaust wise doesnt really affect the IAT too much unless you float the valves and the soot is able to get back into the intake manifold...and with 45+ psi of positive pressure going INTO the cylinder, no soot will blow back to the manifold. the previous owner of my truck ran a filter that was over oiled, which is why mine was in such bad shape.
doug smith showed me the build up in the manifold when i took him my head for the work. i barely oiled my filter the one time i cleaned it. last time i had the grid heater off my manifold was as clean as when doug did the machine work. i had never cleaned the IAT when i re-did the head tho...and i put it back in dirty and black as can be because i thought it was supposed to be black.
Old 12-11-2006, 03:52 PM
srt20's Avatar
Originally Posted by graphitecumnz
I'd reckon that as long as your truck has sat for an extended period of time in those temps(6+ hours) and your high idle still isn't working, then you have a sensor issue. These engines really need to be cold soaked as they retain quite a bit of heat. My high idle works just fine as long as the truck has sat long enough. A week ago, high idle worked at 6:25 a.m. after sitting in sub 20's all night(9 hours) but at 11:45 a.m. high idle did not activate after sitting in the same sub 20's...
You're not plugging it in are you??
My high idle works even with the truck plugged in overnight at 10-20F or so in the morning.
Old 12-11-2006, 06:18 PM
jlebrun's Avatar
i have a 98.5 and mine high idles all the time when its cold with stock programming, and a buddy of mine has an 01 that didnt high idle even when it was around 0 F, so does my truck have something different, or is that just a stock setting for it to high idle when its cold
Old 12-12-2006, 07:59 AM
RowJ's Avatar
I believe the 01's & I know the 02's don't have the high idle in their factory software.
It's like the block heater cable on the 03's.... You have to go back to Dodge, with wallet in hand, to get it.
RJ
Old 12-12-2006, 09:49 AM
blueandsilver02's Avatar
anybody in the DFW/ N. TX area have a smarty that I could try out? I have been wanting to try one out just to see what it is like and so i can get this high idle thing too.
Old 12-12-2006, 10:43 AM
RowJ's Avatar
Come on over to the dyno in Emory (:45 east of Dallas)...Sat morning. There will be 1/2 a dozen and you can take your pick!
Your welcome to try mine!
RJ
Old 01-17-2007, 09:27 AM
finally had high idle kick in. 23* this morning and it was cold enough to finally make my truck idle up and warm up before going to work. im sure cleaning my IAT sensor helped it some too!
Old 01-23-2007, 06:40 PM
BTW for those who dont think their IAT needs cleaning this is just so you can see how dirty they get...
before
after
90 power ram
03-15-2011 09:37 AM
kicker210
12-02-2009 08:23 AM
cwrhnr
05-19-2009 05:18 PM
jmccart
06-12-2007 02:12 PM
dieselnewbie
01-18-2005 10:48 PM
Quick Reply: high idle
