high fuel pressure
1 Post
high fuel pressure
I have a 392 walbro feul pump on my truck. It usually run about 20 to 23 psi of fuel pressure until I mash the pedal. Yesterday when I started my truck the fuel pressure was at 35 to 40 lbs of pressure. I changed fuel filter and it did not change. With the pedal mashed it still runs 30 lbs of pressure. Sould I be concerned about this. Any info would be helpful.
it could be the bypass valve sticking. it only takes a couple of minutes to rip it out of there, take it apart, and clean it.
De-burr the piston while you're in there.
Mine did the same thing once, went in, cleaned, de-burred, and its been working great ever since
mullishacrew
03-18-2012 12:41 PM
GlennRMK
05-24-2007 10:46 PM
Power Ram 250 C
02-20-2007 11:08 AM
