High Flow "Custom" Air Intakes
Old 09-25-2007 | 08:09 PM
Xtremewheeling's Avatar
I'm looking to build the most efficient air intake for my '96 CTD. I'm currently running a AFE Filter in my stock box. I don't care to spend $300+ on an aftermark plastic set up plus i have a 3" body lift so the tubes will end up short. Anyway what do you guys think is the best way to get "good, clean, COOL" air into my turbo. Anyone have any custom designs they've built. I can'
t go through the headlight (street legal), thinking of a functional hood or bringing the air in from the bumper.. Anyone else ever think of the best way to do this??? My fabrication options are unlimited...
Old 09-25-2007 | 08:19 PM
cbtumedic's Avatar
You could always draw air in from the cowl area, i believe one of the scotty intakes used to do this, Here's a link to the printable instructions on this now discontinued product, althoough you could fab something similar. These used to get really good reviews for cool air and lower EGT's. Just an idea.
Old 09-25-2007 | 08:40 PM
Muddin_dude06's Avatar
Yeah the Scotty II drew the air from the stock location and then a 4" hole cut in the cowl. I have thought about fabbing one as well...
Even with a body lift a Air Aid Quick-fit would hook up.
Old 09-25-2007 | 10:15 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I heard from Scotty that the Scotty IIs may be making an appearance again
No set details yet, but he is looking into it.
XLR8R's Avatar
I like the Super BHAF:
Provides enough Cummins-spec airflow & filtration for 2 CTDs...
and has an optional cowl-induction hat that draws from the high-pressure cowl plenum.
http://lazarsmith.com/SuperBHAF.html
Old 09-25-2007 | 10:55 PM
dieselfuelonly's Avatar
DTR question asker
Wow thats quite the filter you've got there!
Old 09-25-2007 | 11:03 PM
XLR8R's Avatar
... it is a bit loud though - the compressor sounds very unique through it.
Old 09-26-2007 | 12:05 AM
Aosipower's Avatar
XLR8R when will these be available for 2nd gen's? The site says they are under development...
Old 09-26-2007 | 02:44 PM
XLR8R's Avatar
We're just waiting for the end of the season next month (down here it's the DHRA HRP Nationals) to package it on one of the 2nd Gens - probably the '99, so it ought to make a nice Christmas present.
Old 09-26-2007 | 03:03 PM
Aosipower's Avatar
nice! Will it have that optional cowl thing? And how does that work, does it draw air from the front or back of the hood?
Old 09-26-2007 | 05:32 PM
Adam3291's Avatar
I will be first in line if he brings it back.
Old 09-26-2007 | 05:34 PM
Lil Dog's Avatar
The Scotty II is the champ for moderate powered trucks. Cowl induction works great on the open road, when you need it anyway. The dyno doesn't do the system justice. I went from a BHAF to the SAII and gained 100°F EGT room on the stock charger. I haven't tested with the S300/BHAF combo.
SAIIs on the rebound.. Wow, that would be good news. I have heard of cracked and broken old SA system getting sold for as-new prices.
Old 09-26-2007 | 06:35 PM
schoust's Avatar
Does anyone have anything Home made that works and that is inexpensive? Not cheap just flat broke at this point!!
Old 09-26-2007 | 08:44 PM
XLR8R's Avatar
That's the plan!
With the stock airbox & ducting out of the way, the flexible air deflector is removed from the passenger side of the CAC, so ambient air has a straight shot at the filter bank.
The cowl induction draws from the high-pressure area where the windshield and hood meet, under the stock hood.
Of course, the SuperBHAF hat can be adapted to a cowl-induction hood as well.
You can see the setup on that page of the website.
Old 09-26-2007 | 08:46 PM
HOHN's Avatar
Well, I'm still running my prototype PowerCore BHAF with good results.
Well over 1000cfm at only 8" water. 99.9% initial efficiency at 10 micron.
Donaldson rocks
I'm actually considering cutting my hood and doing a ram-air. (with the scoop facing the RIGHT way
Justin
