High EGT's and black smoke
Old 06-14-2007 | 10:15 PM
Pirate's Avatar
I noticed recently my EGT's are higher than normal under similar conditions and the truck now blows black smoke very easily. Prior to this it was difficult to get much smoke. With the comp box off it will still smoke more than it used to. Now when it goes into overdrive and I am accelerating I get quite a bit of black smoke. My EGT's hit 1300 fairly easily and if I am towing a heavy load I can get into the 1500 to 1600 range any time I have to go up a hill.
Any suggestions as to what the cause(s) may be?
Thanks for any and all help.
Old 06-14-2007 | 10:34 PM
600 Megawatts's Avatar
Muted User
Do you notice boost being down a bit?
Do you hear any hissing from under the hood ??
Could be your lower intercooler boot has spent too much time rubbing the inner fender liner/wheelwell and its got a hole. Mine worked iteself into such a state so gradually and over such a length of time I didnt even notice it, until it finally became a chore to drive without smoke, and I finally noticed the drop in peak boost.
Zino
Old 06-14-2007 | 11:19 PM
kenny1987's Avatar
all u have to do is take some pliers and bend the piece up i had a friend tell me about that lucky me LOL
Old 06-14-2007 | 11:49 PM
Ph4tty's Avatar
High egts and smoke does sound like a boost leak. A 3" pvc plug with a valve stem can be used on the turbo outlet to pressurise the system. Spray it down with soapy water and look for bubbles if the leak isn't immediatly obvious. I tried this recently with a 4" cap and cac hose on the turbo inlet and it seemed to work pretty good for a $5 in parts plus what I had sitting around
Old 06-15-2007 | 09:36 PM
Pirate's Avatar
Thanks, I'll check for boost leaks. I have not noticed any changes in boost levels though. With no load I can hit 1500 and 1600* with WOT for short bursts.
Old 06-15-2007 | 09:44 PM
bigmack2500's Avatar
look at the simple stuff first when is the last time you cleaned your air filter!
Old 06-16-2007 | 01:43 AM
Rattletrap1's Avatar
What he said.
Old 06-16-2007 | 07:33 PM
Pirate's Avatar
Air filter is good and very clean. What it seems to come down to is not enough air for the amount of fuel being delivered.
That definately gives me some where to start looking.
Thanks for pointing me in hopefully the right direction!
Old 06-16-2007 | 07:39 PM
Pirate's Avatar
Found the problem. First rubber hose after the turbo split right at the top clamp. Easy enough to see but you guys let me know where to look.
It seems we always get first rate suggestions on this site. Thanks to all who replied.
Old 06-16-2007 | 08:36 PM
Ph4tty's Avatar
I'm not sure where you are in Va, but we have an event coming up at the end of the month https://www.dieseltruckresource.com/...d.php?t=152094
Old 06-16-2007 | 09:14 PM
Pirate's Avatar
Wish I could attend but I'm in BFE, VA. Not too far from Roanoke/Lynchburg area. And the wife already has plans for that weekend at the lake.
Old 06-17-2007 | 12:09 AM
J Lent's Avatar
I have 2 stock rubber boots sitting here if you want them. They are both straight boots. Let me know & I'll ship them out.
Old 06-17-2007 | 07:32 AM
Pirate's Avatar
J Lent, you have a PM
steve21
09-12-2008 01:34 PM
zachv
05-13-2006 08:56 AM
swansong04
05-02-2006 01:20 PM
bensdad_canada
05-09-2005 11:56 PM
dhe9
11-14-2003 08:31 AM
