High EGT'S
High EGT'S
I need some help. I have a 2002 3/4ton 4x4 with an auto trans. And i have high EGT's with the truck being stock. i have tried everything that people have told me. i have checked my air to air hoses, check the injectors(because i bought the truck used), checked fuel pressure, even installed an after market fuel pusher pump, straight piped it, had the truck dino by cummins. and they said there was no sign of high egts on the dino, but i didn't get to see them dino it. what my egts are, at idle they are around 300 degreese and i can get the egts over 1500 degreese are more at full throttle at 75mph. my manfold has turned white from the high egts. Has anyone had this problem with this. i don't know what to do. i am temped to sell the truck because of this. please let me know.
Rob
Rob
Don't sell it, there is probably a good reason why it is doing that...........I'm trying to think here!! You might have an internal oil leak inside your turbo that might be heating things up, I know it's happened before.
I looked in your profile and saw that you have a chip.........have you tried turning that off or unplugging it to see what your temps are then? I know with my Edge COMP I can smack 1400* pretty dang quick if I stay on it.
And just out of curiousity, how long do you run at those temps?
~Nick
~Nick
Rob,
Welcome to the DTR!
300* at idle is normal. 1500* at 75 mph is not....for stock. Cruising at 60 mph you should be no higher than 700*...ever checked?
1500* would not turn your manifold white unless held there for a long time...in which case your truck would have melted a piston. Drag racers, hitting 1700* for short periods, have not seen discolored manifolds???
IF your sure it's stock....I would suspect faulty gauge.(other than the "white" manifold...which have never heard of before).
Assuming you have gauges? How do you know the truck is stock...if bgt used with gauges...or did you add those?
Fill in your Signature (User CP in header) so we know what you have on your truck.
Hang in there....the answer is on this web site...with someone. Have patience grasshopper!
RJ
Welcome to the DTR!
RJ
your profile says you have an edge box...if its an edge comp with stock intake and stock exhaust i can easily see why by the time you get to 75mph at full throttle the truck is seeing those temps...turn the box off or dont run it too hard to long or you will melt a piston. get some more air into and out of that thing and you will see a big difference
edit-your profile says you have exhaust...what is it? a 4" system is good, straight piped is better
Yes i do have the comp box on my truck. and i turn the box off and it gets up to 1500 degreese. when i turn the chip on i can barry my gauge. yes i have tried more then one gauge. so no i don't think it is faulty gauge. yes i have an K&N air filter. had have drove the truck with no filter at all to see if that changed anything. the exhaust i have is a 4" system i custom made. my parents own a auto parts store so what i mean by i custom made is i bought the 4" down tube out of a system and then put a 45 degree angle out before my rear axle. so there is no muffler are restriction.
the white on my manifold is not that white but it looks like you took a tourch to it and it gets that white flake on it. i have ran these temps for about a min and then shut it down. i don't want to burn my engine up. but is it under engine warranty. i know the truck is stock because i talked to the first and only owner and he said he did nothing to it. and i pulled the injectors just to make sure.
also you say the oil in the turbo. i see some oil every oil change but nothing that looks like a problem. i don't have the turbo silencer on it. but they said that don't make a different.
i will be putting pic. of my truck soon. i am at work now and my g/f has my camera.
You need a bigger turbo for sure. Also, ditch the K&N and go with a scotty 2 intake. I've got a ksb-1 turbo on my truck with the scotty 2 and even with the comp on 5x5 and 275 injectors I can only hit 1225*-1250* by the time I hit the speed limiter at 117mph.
Originally Posted by signature600
The white manifold sounds like someone has painted it, and it has burnt the paint of...but then again, I'm not looking at it, either!!
Chris
Chris
I've seen them turn colors before, not sure exactly what causes it but I have seen them!! My old work trucks manifold looked like that until I replaced it...........had a small crack in it!!
~Nick
Chris
Chris
My buddy with a 12 second Dmax hits just over 2000* by the end of the 1/4, so 1500* is high but not the end of the world. A bigger turbo should help feed more air at lower temps into it. Also you can get a 4" turbo back for under $300 and that would help too.
