High EGT's
High EGT's
Why is it that on a 4-5 second WOT pull I see egts up of 1400. It will it 47-48psi. The smoke clears by 2200rpm. I thought that to have egts like that you would need to have too much fuel.Any suggestions.
an intake and intake manifold will not drop it that much it will still be too hot.. the injectors your running are too big you dont need that big of an injector to get em to light 90s can even light a 64
1400 is not hot for a WOT blast. You shouldn't get concerned till your over 1600 for more than a few seconds.
Sustained towing EGT is a different story. 0 to 130 MPH WOT runs are a different story as well.
Too true. The intake side isn't your problem. Twins would fix it. Other than that, the stix are too big.
You could run methanol/water spray to cut some the egt's. Start with higher intial boost pressure. I drop 200 deg's running a single 325ml nozzle and just windshield fluid. A biggie turbo would help as or go for the big bad twins. With my current stick the highest egt's I have are around 1200 deg's without spray and around 1000 deg's on full spray.
I have an aftermarket intercooler, its hardly drop the egt's at all. A cam, better sticks and/or bigger turbo (twins) is the best way to drop egt's. A better IC will just flow better at higher flows and wont have as much dP drop across it. The methanol/water spray works are well but only work when there is fluid in the tank.
