Hi-performance filter outlets?
Guest
Posts: n/a
Since I'm kind of unsuccessfully trolling on subjects that everybody already knows about, like pulling the silencer ring,
, I thought I'd ask this.
Isn't the amount of air a BHAF or an AFE or K&N flow restricted by the four-inch outlet hole? And is it possible that the BHAF, the AFE and the K&N all flow more air than the outlet can handle? And if that's the case, wouldn't your turbo and intake receive the same air charge from all of these filters, so that other than temperature, it doesn't matter what you use? I asked Fleetguard about this regarding the BHAF, and they told me they didn't have those figures, but it was a good point.
Don't hurt me for asking! ;D
ascraeus
![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
ascraeus
Re:Hi-performance filter outlets?
The amount of airflow through the 4 inch inlet hose would be dependent on the amount of restriction from the filter. A 4 inch pipe can flow a lot of air if it has no restriction.
Guest
Posts: n/a
But the more surface you've got on the filter, the more it flows, right? So if you've got a lot of surface, like the BHAF, or a lesser amount of less-restricted surface, like the AFE, much more than four inches squared worth, isn't it possible you'd reach the outlet restriction before you'd reach the filter restriction?
I guess my question is, has anyone ever tested the flow of a four inch outlet? And then compared the filter flow figures, to be sure? Somebody somewhere must have figures.
Just more science.
ascraeus
Just more science.
ascraeus
You're looking at it a touch wrong...It all adds up to a total pressure drop (or suction-how ever you want to look at it). The drop across the filter + the drop through the tube. I suspect the drop through the tube is pretty negligable when compared to the drop across the filter - even with a size huge filter. So...to answer your question (I think) you can't get a filter big enough to overflow the tube - I suppose if you had a filter that took up the size of the bed you might turn the numbers around to the point where the filter was negligable compared to the tube...But basically youre after the lowest restriction inlet you can get -which is the sum of the tube plus the filter....I sure hope that makes sense to someone else
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
Guest
Posts: n/a
MisterKTM, "Suction, not flow", that makes sense. But as far as a filter being the size of a bed, have you ever removed the filter element from a BHAF and straightened out the pleats? Yup, you guessed it, surface area as big as a bed! ;D That's what got me thinking about this in the first place. (My dad has a damaged one he's replacing, so out of curiousity we cut it apart.)
And BigBlue, it takes more time for you to think up answers than for me to ask stupid questions!
ascraeus
ascraeus
Its not ONLY the size of the filter that is important. The filter material has a lot to do with the retriction factor. When K&N introduced its gauze design it revolutionized the way air filters where made.
![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
I don't doubt that those big filters are as big as the bed - there is a lot of pleats in them for sure. What I'm saying is the fact that you have losses from going through the tube doesn't have anything to do with the losses through the filter - The lower you can get the restriction through the filter the better - as they are both additive at the point it gets to the turbo inlet<br><br>As to seeing no gains with a low restriction air filter...the stock filter was probably doing just fine with no other mods to the motor- if you were to add fuel (fuel plate or chip) then you would need more air to go with the extra fuel and then you probably see a difference. The stock filter may not be able to supply air at the increased demand - compared to the K & N.
My theory: If you produce the same boost wheres the gain? Air temp./ Air density. ??
Location: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=Amish hauler link=board=7;threadid=13432;start=0#126708 date=1050025323]<br> My theory: If you produce the same boost wheres the gain? Air temp./ Air density. ??<br><br>I apologize for jumping in but I think it's sort of the same question...you can only flow as much air as she'll take..right? Anything past that would be boost wouldn't it?<br>[/quote]<br><br>You can only flow as much air as the truck wants, but the objective is to flow this air as easily as possible. So proper air system design is not just strictly related to air flow/air restriction of the filter on a bench. You want to allow the turbo to pull air as easily as possible (or ideally, push the air to it so it doesn't have to pull a doggoned thing) so you don't increase drive pressures, and pull the turbo out of its efficiency map. The harder the compressor has to work to get its air, the hotter that air will be after it leaves the turbo.<br><br>Rod
Guest
Posts: n/a
[quote author=Push Rod link=board=7;threadid=13432;start=0#126825 date=1050048267]
Rod
Rod
Which brings us back to removing the so-called "silencer ring" and the air flow effects caused by its "theft". . . . OK, I'll shut up.
ascraeus
Timmer
10-02-2007 11:39 AM
