Here's My #s, How Are They?
i finally got all of my guages in that i wanna get put in. fuel pressure, pyro, tranny, and boost. so now i figured i'd post all of my numbers/readings and see how i check out, everything seems great, but just wanna make sure so here it is...
FUEL PRESSURE: Idle-18 psi, WOT-15 psi, Cruisin~16-17 psi
PYROMETER: Idle~350*, WOT~900*, Cruisin~600* i think
TRANSMISSION TEMP: Idle~130*, WOT~160*, Cruisin~150*
BOOST: Idle-0 psi, WOT-32 psi, Cruisin~6-10 psi
take notice everyone that i put the approxmately sign (~) i didn't take real good note of all of the numbers, these are all by memory, so that's prob why, but i know it's pretty close. but besieds, isn't lower better?
Wish I had that kind of fuel pressure. I'm still running a stock lift pump. Not sure which aftermarket setup would be best for cold MN winters and road salt.
dieselfan
and i took my truck out again tonite guys and i checked the pyro a little closer, it's actually what looks to be at about 1000*, it's right before the yellow anyway. so, i think it's ok and reading right, what you think?
thanks for saying somethin finally, i guess my rant post worked
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
oh ya, what about that tranny temp though, is that in the norm, i'm concerned about that, cause i rigged up my own fittings and stuff and i'm not too sure that those readings are real accurate but then again, maybe they are.
everything seems alright .i got mine at test port #2 and they seem the same. looking good.
dieselfan
