Helper Pump Wiring?
Old 09-24-2006, 02:32 AM
DL1221's Avatar
Originally Posted by dsl kicks gas
i have a extra campagin too, but the main problem i see is gettin somethin to thread in to the pump it's self. and the plug for it
From another post:
If you do need to add the second Campaign pump in the frame as a pusher, don’t forget that these pumps come with 12mm ports for use with the stock banjo bolts, so you will need some special adaptors to fit the 3/8 fuel line. Vulcan Performance has them for $10. Oh, you will also need a braket to bolt the pusher pump to the frame, Vulcan also has one. And you know about the relay and harness, as the other post explains.
big stinky
10-03-2009 08:32 PM
dsl kicks gas
12-02-2006 07:48 PM
Hounddog
01-18-2005 03:38 PM
PHONSE
04-28-2003 06:08 PM
PHONSE
04-27-2003 05:25 AM
Quick Reply: Helper Pump Wiring?
