HELP...turbo install gone bad...
ok so tonight iam trying to remove stock turbo to replace with htt 64/71/14 well got all mounting bolts that hold turbo on but i rounded the back bottoom off badly so what to do???help please mike
Did you round of the nut real bad.... is tgis what you are asking??? Is it all off and you just need to know what to do next????
Just replace it. It is just standard hardware.....You can get it at any hardware store.....
no i havent even got that one broke lose yet but it is rounded off pretty bad and now i cant get anything on there with a bite..oh sorry for not makeing my self clear
While you have the manifold off and you wait for the new gaskets you could port-match it to the head with a die grinder... helps with spoolup and egts.
AlpineRAM
AlpineRAM
Just a note, Of course they make extractor sockets and tools that will take out a rounded bolt. I recomend if your changing your charger , you need a manifold as well! But if it rounded off, These guys are giving good advice! Much easier just to take it off and go from there! If i can help give me a call!
You cant get anything in there other than a wrench. It took me alot less time to get the cut off wheel and just cut the stud and bolt off real close to the flange and use a chisel to finish it than it would have to take the entire manifold off. I agree will be easier on the knuckles and what not but if you break a bolt off in the head you will have two problems and not just one. Good luck whatever you decide.
vise grip makes a special bolt extractor that grabs rounded nuts. http://www.irwin.com/irwin/consumer/...rwinProd100512
sears normally carry this. be sure and put penetrating oil all over. then hit with copper hammer to loosen. leave overnite to allow oil to work.
last resort is of course cut nut off with die grinder, then replace stud.
be sure and use anti-size compound upon assembly.
