HELP: Truck died and won't start?
Old 07-21-2005, 06:47 PM
GlennRMK's Avatar
Ok, I have been trying so hard to get my fuel pressure gauge hooked up with no success.
Today, I bought air brake hose to try, and seemed to seep a little bit. I am trying to hook the gauge up to the scrader valve. Used a fuel injection tester hose to do it, followed by a needle valve.
When I had it hooked up, it seemed low, 11 PSI at idle.
Then, all of sudden while it was idling it died.
Now you can crank it for a few seconds and nothing. Seems like no fuel. Could the VP or lift pump just die all of a sudden, with no warning? Always fired up very fast before.
Or could the big hose have drained the VP or something, or could I have gotten air in it or something? Haven't opened up the fuel filter housing to see if there is fuel, should I?
I give up on the fuel pressure gauge. Can not make it work! 1/8" tubing leaked. Don't know what to do.
Please Help. Thanks.
Old 07-21-2005, 07:04 PM
Clunk's Avatar
Turn the keyswitch just enough to "bump" the starter then release it. You should hear the lift pump come on and run for around 30 seconds. Do this 3 more times then try to start the motor.
Clunk edited: This should get any air pushed out of the system.
GlennRMK's Avatar
Fuel filter housing is full of fuel
Still won't start?
What the heck could it be?
It cranks, but doesn't start?
Could be electrical?
Old 07-21-2005, 07:10 PM
GlennRMK's Avatar
Tried that.
Still won't start. But I do hear the lift pump come on.
Did the VP die? Is that possible?
Should I pull my VanAaken off? Maybe its defective?
Old 07-21-2005, 07:27 PM
Clunk's Avatar
You might try that. You can also turn the keyswitch on-off-on-off-on and see if any codes come up on your odometer.
Old 07-21-2005, 07:32 PM
GlennRMK's Avatar
Ok, thanks
Pulled VanAaken. Repeated procedure.
Still nothing.
I'm assuming if the VP died, it won't start, period?
Old 07-21-2005, 07:35 PM
GlennRMK's Avatar
Says
P PCU
P DONE
xxxxx mileage
Clunk's Avatar
What about the code check?
Old 07-21-2005, 07:38 PM
Clunk's Avatar
Does fuel squirt out the VP Schrader Valve if you loosen it a little bit while the lift pump is running on the "bump"? Gotta be sure fuel is getting to the VP.
Old 07-21-2005, 07:47 PM
GlennRMK's Avatar
Will try that
Is that a code or does that mean no codes?
Heading to work to get a scan tool when someone shows up.
Old 07-21-2005, 07:50 PM
Clunk's Avatar
That means no codes so there should be no problem.
Old 07-21-2005, 07:56 PM
GlennRMK's Avatar
Fuel poured out like no other sprayed like SOB!
So, that means the VP is ok right?
What else?
Old 07-21-2005, 08:24 PM
phox_mulder's Avatar
Now you need to crack a couple injector lines, at least 3.
Just loose enough for the air to get out, crank the engine no more than 20 seconds or so, once you see fuel coming out of the lines, tighten thighten back up.
Be very careful, as the fuel is pressurized to around 4000 psi, easily can cut into skin, and Diesel in the blood stream is very bad mojo.
Let the starter motor cool for a bit, then crank again, it should start and run really rough but eventually smooth out.
If it still doesn't, repeat the process on the remaining lines, if you don't ever see fuel out of 1 or more of them, then the VP is indeed toasted.
If this doesn't do the trick, then it might be something else, like the cam posistion sensor or the VP has bit the dust.
phox
Old 07-21-2005, 09:12 PM
GlennRMK's Avatar
Fired right up.
Cranked on it a little longer and all of a sudden it fired up.
Not sure what the deal wasl.
Going to bring it to Dodge, and see if I can get a new lift pump. Pulled all my stuff off.
Is there a $100 deductable to get the lift pump changed?
Old 07-21-2005, 09:59 PM
There shouldn't be.
phox
Quick Reply: HELP: Truck died and won't start?
