HELP----PS62/14 Install
Old 10-10-2005 | 10:18 PM
sshelly's Avatar
I'm trying to install my Phat Shaft 62 on my 02. After you get the Hx35 off, there are two stud left in the exhaust manifold, while the Hx35 keeps the other two. The new turbo just has holes (not threaded). Can I just go down and get two bolts to hold the turbo to the manifold and use the existing two studs for the others? Also, the drainage outlet on the PS62 is retangular, where as the one that went to the HX35 was round. The gasket that you get with the PS62 is retangular. Is seems like it will seal okay, but I want to make sure. Thanks!!!!
Old 10-10-2005 | 10:25 PM
PourinDiesel's Avatar
Sounds right on the drain.
The bolts to the manifold might have to be made or sourced at the hardware store.
Old 10-10-2005 | 10:27 PM
BigBlue's Avatar
My roommates super b was the same way. We just used the 2 existing studs and went and bought some bolts from home depot for the other 2. It's been working great.
Old 10-11-2005 | 12:41 AM
CTD_Neil's Avatar
My HTB2 from High Tech came with all the hardware and gaskets for installation. Just use a couple of good bolts.
Old 10-11-2005 | 09:23 AM
RowJ's Avatar
As said above.....use the two studs and get 2 bolts for the other holes. Recommend Fine thread, stainless steel.
Cut the gasket to fit and after hook up...run it with the Air filter off for a few minutes- to check for possible leaks. Should not be a problem.
RJ
4969joes
02-27-2012 08:59 AM
jmccart
32
04-01-2008 09:50 PM
Smkn600CTD
03-30-2006 06:25 PM
gsdog1
11-27-2005 11:59 AM
lightening ram
11-07-2005 09:01 AM
