Help a newbie out, injector question
Gentelmen,
I have a 95 12V and want to add some power to her. I purchased a #5 fuel plate kit from TST, and wanted to know if adding 275 injectors would be worth it, or would the power gains from the fuel plate counteract the injectors? I have a CAI, exhaust, and gauges currently and now I'm ready for some more power.
Thanks
Thanks
The fuel plate wouldn't counteract the injecotrs at all it would only add. If you're looking for a small power bump the 215's may be right for you, but if you're wanting a fair sized power increase you'll probably need to look at something a little bigger than 215's. @ other things that you should do if you're ready for power is a timing advance and a GSK.
Yes, the injectors and the plate will mean you will have even more power...
But the big question will be what kind of tranny do you have? If it's an auto, then you'll be at it's limit with just the plate, and start saving for a build-up.
The truck has a 5 speed manual. It still has the original clutch (with 188k) so a better clutch setup is definately in order. The fifth gear "nut" job was done about 10k ago so internally the tranny should be fine.
A7-98RHELPER
08-20-2012 07:36 AM
billycj7
04-27-2008 04:17 PM
oscaroc
04-02-2005 12:14 PM
