Help with Juice w/ monitor
Friend of mine bought a edge juice with monitor for a 02 truck, his is an 01 so he needs a adapter for the MAP ok thats cake.
But I can't figure where everything else goes, got the data link hooked up but all thats left are doitz (sp) type connectors.
And what really gets me is theres no wires for the IP tap (ground or wire tap)
So I'm not sure if or what I'm missing.
Help please lol
PS the edge instalation manuel shows none of the duetz (sp) type conn's on it either.
Help please lol
The wire tap for Edge if I understand correctly has a wire tap, and a ground. The deutz connectors are probably for hooking up to the map sensor, egt probe, trans temp, and fuel pressure.
If you didn't get sensors with it then you can't use the plugs for much.
I have no first hand experience, but I gotta imagine it's like my adrenaline/pulse.
nitis
02-26-2007 07:38 PM
Hondo
03-03-2005 06:40 PM
