help identifying edge product
oh ok kool do you know what it is exactly? and old comp? there is just one pink wire going out under the hood other then the map sensor plugs so is that the pump tap wire?
It's the Edge Pulse, they offered the EZ, Pulse, & Comp at one time, I'm thinking the Pulse was around 100hp though, was just a touch less than the Comp if I remember correctly? definatly the PUlse though! Dusty
ok thanks cl2000 and dusty! i actually got it all hooked up tonight and took it for a little drive i dont think its working though couldnt really tell any difference, the light comes on flashes once or twice or three times for the different settings. ill have more time tomorrow to check it out.
stock03
04-22-2011 09:52 PM
