Help Hooking Up A Fuel Gauge
Old 06-13-2007 | 04:44 PM
EverydayDiesel's Avatar
I got a rediclous deal on a electric auto meter cobalt 30psi fuel gauge and couldnt pass it up.
My question is...where do I hook it up at? and what fittings do I need. it comes with a 1/8" NPT Sender.
does anyone have any pics on where the hooked their line up?
Old 06-13-2007 | 04:59 PM
dodgezilla04's Avatar
http://www.genosgarage.com/prodinfo.asp?number=LT_FFCPP
http://www.genosgarage.com/prodinfo....BF-LONG-TAPPED
these'll make life easier
Old 06-13-2007 | 05:11 PM
thanks. do i still need the banjo bolt if i get the filter cap?
the cap says it accepts a 1/8th inch npt which is what i have on the fuel pressure gauge sender
Old 06-13-2007 | 05:18 PM
does that monitor before or after the filters fuel pressure?
Old 06-13-2007 | 05:23 PM
no, you only need 1. your choice. the banjo is cheap, the cap looks cool.
Old 06-13-2007 | 06:08 PM
do both of them read the pressure after the filter?
i want to monitor the pressure that the VP44 sees.
Old 06-15-2007 | 12:17 PM
where exactly does the banjo bolt go?
Old 06-15-2007 | 12:20 PM
you can put it on the filter outlet, or the vp44 inlet.
a banjo fitting is a connection the takes the pipe 90* to the component you are plumbing. does that make sense?
Old 06-17-2007 | 02:21 AM
yeah... im going to order the banjo fitting right now.
Does anyone have a picture of where it goes?
Old 06-17-2007 | 07:27 AM
i reccon this is where everyone is hooking their banjo adapter up at
Old 06-18-2007 | 05:31 PM
is that the spot?
Cholmes
03-03-2010 07:51 AM
HDBeauty
04-12-2007 06:26 PM
Gene007
06-17-2003 03:08 AM
