HELP...Error 14
Old 05-10-2008 | 05:43 PM
psd tuner's Avatar
HELP...Error 14
i have a smarty downloader for the 98.5-02 dodge. i used it on a buddy truck to let him try it, so the dowload got interupted cause of a loose wire on the OBD-II port. so i pushed in all the wires and restored the ecm to stock, it downloaded but after the download it said error 14. so i tried to put the smarty on my truck and it said VIN locked. how do i get it back on my truck, cause his truck is on the stock setting and so is mine but it says VIN lock. I want my power back, it still has a little cause of the injectors but it aint what it used to be
Old 05-11-2008 | 12:12 AM
psd tuner's Avatar
anybody...i really dont like having my $650 not working on my truck or any truck at that matter.
Old 05-11-2008 | 04:07 PM
psd tuner's Avatar
updated to the latest version the 1.22B. still no go. why wont the stupid thing work...oh sorry its called a smarty not stupid.
Old 05-14-2008 | 05:05 PM
psd tuner's Avatar
well smarty says to check the connections...i checked all of them. they said it has to return to stock w/o any errors. this dont help me, i am running out of options. i dont wanna swap out ecms on the trucks, i dont think the truck will like that to much. well its almost been a week w/o my smarty.
Old 05-14-2008 | 06:21 PM
Bob Wagner's Avatar
error 14 is a communication error ,does the truck run?
call
Old 05-17-2008 | 11:09 AM
psd tuner's Avatar
some times it will run, then i will try to download the stock setting and sometimes it wont run. does mads have a phone line i can reach them by. i need to talk to somebody over the phone because i hate e-mails.
Old 05-18-2008 | 07:43 PM
Bean's Avatar
Sounds like the OBD port still has a bad connection. If it powers up the Smarty you have 12v and ground. There are 3 other wires that need connection, #2, 7 and I cant remember what the other one is unless I look at my pin out sheets at the shop. If any of those 3 have a bad connection you will get a error 14.
Old 05-18-2008 | 09:55 PM
psd tuner's Avatar
thanks will look in to it.
Old 05-19-2008 | 10:15 PM
psd tuner's Avatar
yeppers i bent the 2 slightly longer prongs in the center and it worked. no more error. now my truck is happily enjoying the smarty again but the tranny is about to die. it has some serious slippage.
10HAAP
09-19-2006 10:20 PM
benterry
02-20-2006 10:56 AM
sandpuller2004
02-13-2006 02:54 PM
newtododge
08-16-2005 12:13 AM
StillPlowN
02-15-2003 07:04 PM
