Help with EGT's
Help with EGT's
I have the wire tapped on the comp and gauges installed. I also have my stock 3" straight piped. Problem is in 3 or above the pyro hits 1100 all the time. What will help keep the egt's down? <br>Scooter.<br><br>P.S. Might need to move in with someone! Wife just doesn't understand the bomb bug!
Re:Help with EGT's
Is your probe post or pre turbo? Did you install the boost elbow? How much boost are you running? What are you running for an air filter? If you are not running a Scotty II you should definitely consider it.<br><br>Roger
Re:Help with EGT's
hmm I can run with the comp on 5 under full throttle egt's shoot up to 1200 momentarily then it drops back to 900 and sits there when you cross 2700 rpm (starts to defuel)<br><br><br>must be the scotty
![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
jmccart
03-18-2007 10:03 PM
jmccart
14
11-20-2006 06:45 PM
barracuda
08-03-2005 08:59 AM
