help with body lift?
Old 08-26-2007, 07:14 PM
97dodgeram2500's Avatar
i want to put a 3 inch body lift on my truck like i posted before and almost everyone told me to go to performance accessories. well i went to there site as well as many other sites. they all dont make body lifts to fit my year truck with a diesel engine. does anyone with the same year truck of mine or just anyone know where i can get a 3inch body lift that will fit a diesel engine? help would be great
Old 08-26-2007, 08:44 PM
one54ton's Avatar
body lifts are ghetto, get a suspension lift.
Old 08-26-2007, 09:15 PM
mike_ward's Avatar
I would like a body lift also.???? i thank u would have issues with a few different things tho. Like intercooler, Thats one. Ummm and........ i dont know.. lets do it!
Old 08-27-2007, 03:18 AM
zfort001's Avatar
body lifts can cause some issues. some that come up are, bumper alignment, charge air cooler, ac cooler, radiator, shift linkage for manuals and the 4wd engagement lever, sometimes wiring gets pulled a lil tight or wont reach. Highly recomended if you do take this route it to upgrade the body mounts to poly bushings. just some of the issues to think about.
Old 08-27-2007, 10:06 AM
mike_ward's Avatar
Humm,.. ya there were the one i was missing. i might do a 2" insted of a 3
Old 08-27-2007, 01:34 PM
Gotlift01's Avatar
Get the one for the V10.......the kit will work just fine. The only thing you have to modify to get it to work with the diesel is cut about 1 1/2" off of the drivers side intercooler pipe, everything else works JUST fine! But one thing you will need to do is loosen your intercooler boots for movement, once you've got it all lifted, re-tighten your boots and you're done.
The wires, hoses, fuel lines, all of that stuff is easily done. Just double check you have EVERYTHING loose before you lift it. Then you will need a welder and a chopsaw to extend your shifter linkage ( if you have an auto ).
Other than that it is CAKE! The bumper will align....it might take you a little adjusting though....these bumpers never fit for crap to begin with.
I've had mine on for almost 2 years now and I have had ZERO issues with mine. The only reason I did mine was because mine was already lifted 5" with suspension. Well I wanted to move up to 38"s but I didn't want to rip everything I had just bought off, and buy a bigger lift! So this was an option and to tell you the truth it looks great and I haven't regretted it one bit! One thing that makes it look good though, is the factory Dodge fender liners that go in the wheel well on the bed.......mine came stock with them but you cannot see ANY gaps what so ever......I'm serious NONE!
Hope that helps!
~Nick
Old 08-27-2007, 01:51 PM
wcbcruzer's Avatar
I'd do a 2" over a 3".
Old 08-27-2007, 04:46 PM
mike_ward's Avatar
why ( CUT ) 1.5 " of of the intercooler pipe? wouldent you want to extend it?? im really thinking about doing this!
Old 08-27-2007, 05:43 PM
Gotlift01's Avatar
No, trust me it needs to be shorter......the intercooler pipe goes from the intake horn to the bottom of the intercooler. So when you raise the body it's reducing the distance between the bottom of the intercooler and the intake horn......thus needing a shorter pipe.
~Nick
Old 08-27-2007, 05:46 PM
Gotlift01's Avatar
One other thing I forgot to mention......swapping injectors is SOOOOOOOOOOO much easier having the body lift. No more tight spaces to work with!!
~Nick
Old 08-27-2007, 05:50 PM
mike_ward's Avatar
oh, ya ya, thats right it goingt up not down.
Old 08-27-2007, 05:56 PM
Gotlift01's Avatar
Yep, there is two ribs on the pipe that help the boot seal and keep it from blowing off......I went down to the first rib from the top of the pipe and cut there. You'll know what I'm talking about once you see it.....it measures almost exactly an 1 1/2".
~Nick
Old 08-27-2007, 08:34 PM
mike_ward's Avatar
thanks nick, one more thing where did you get your kit. ive been looking around on ebay and havent seen a thang for the v10. where did you get yours? web site or whatever and prices.
thanks again!
Old 08-28-2007, 01:56 AM
1BAD4X4's Avatar
http://www.rockymountainsusp.com
Thats where I bought my body lift for my 02 1500 and thats where I plan to buy my bodylift for the 2500 if I go that route.
Old 08-28-2007, 08:58 AM
Gotlift01's Avatar
I bought mine from 4wheel Parts here in Denver. It's been so long ago I don't remember what I paid for mine.
~Nick
Quick Reply: help with body lift?
