Help with Blue Chip FMS install (check engine light on)
Old 09-04-2005 | 09:40 AM
tbishop1's Avatar
I just installed a 2000 model year Blue chip FMS with my Diablo power puck. I do not have the pyro thermocouple installed yet (need to find NPT tap). Everything seems to be working fine, but from when I first turned the key after the install my check engine light is on. I did use the included pump tester before hooking up the box. Any ideas?
Old 09-04-2005 | 01:13 PM
smokindog's Avatar
The best thing to do is to contact Chip directly. I've heard he hasn't exactly been Johnny on the spot with the answering of his phones lately, but you need to talk to him to get it straightened out.
Old 09-04-2005 | 01:45 PM
dodgediesel4x4's Avatar
You check for any codes yet?
Old 09-04-2005 | 03:14 PM
tbishop1's Avatar
Thanks, I will call Chip first thing Tuesday. I did not check the codes (I do not have a code reader for the obdII port). I did disconnect both batteries and turn the key on for 30 minutes and then reconnected them. The light went off for now. Has any one else set a code while installing a fueling box and had it go away?
joefarmer
15
11-14-2007 07:53 PM
600 Megawatts
03-28-2005 12:28 AM
Big P
03-27-2005 09:01 PM
