help with the air dog 150 install
I decided to put the air dog 150 on tonight so I dropped the tank and from the instructions that are sent it is hard to see where the suction tube goes? Do I drill a hole or does it replace the factory line and where does the return go to back to the factory or somewhere else?
For the return you will have to cut about 1 1/2 inches out of the filler tube and install the "Y" that is provided.
If I can offer any advise. Just make sure you get all the fitting tight. Then double check them. Then drive it a bit and re-check the fittings. You dont want to end up like I did. I checked and made sure all fittings were tight except the return line...
I asked around for pics of the install from someone and no one had anything.. I should have taken photos.. I do have the directions in e-mail format. If you want them PM me your address and I will shoot it over.
I drilled the 1 1/8" hole in a flat spot close to the sending unit and right behind it out of the way of the cross member, then I called Toby at air dog and asked him about the return because when I was taking the tank down the factory return broke He told me to use the old 3/8" feed line on the sending unit instead of the 5/16" one and just cut the tube so it will drain like the old return line ( I hope you are all following this because I am confusing myself) so I did this in the morning I am gonna finish it up. So I this all right so far!
Thanks Nike for the tips!
ghstrider87
07-28-2011 08:07 AM
trailinone
16
06-19-2009 04:28 PM
modified03
13
02-16-2009 01:52 PM
curts99
02-14-2008 12:09 AM
