help adrenaline
help adrenaline
I have an 02 I just installed the adrenaline on. The little display does not light up,turn on or anything and my truck will not shut off. If i stall it and start it again with the little display unplugged then it works fine. Bad tune? module? display?
i thought the same thing when i installed my adrenaline, jlent is probably right you need to push the brake or accelerator pedal to shut er down. as far as the light not coming on i cant awnser that.
no pulse and there is no way for me to change settings cause the controller doesnt work. but high idle and tt does work i just cant control it. major thing now is the controller doesnt work.
if i was u i would go download a tune on the box that doesnt have a turbo timer. i dont have the pulse either and i put a sledpull tune on it, went and drove it, decided i didnt like it, turned key off but truck wouldnt die. idk if it had a turbo timer on it but i didnt know what was goin on. i unplugged the box and went and put my old tune back on and all was well!! so go load another tune and try it. and check the power wire for the controler if u aint already.
wurkenman
04-23-2008 07:07 PM
