help with 241 DHD t-case
i got a 241 dhd t-case for my truck witch had a 241 dld on it and i am haveing a problem. the input shaft on the DHD is longer then the DLD. what can i do. should i cut it down or replace the output shaft on my tranny.
Brett
The NV241D is a heavier duty Dodge version of the 241, with a larger input shaft and larger bearings to withstand the torque of the V10 and diesel engines.
The NV241HD, an option on Ram 2500's and standard on Ram 3500's built after 1998, has a stronger case and wider drive chain to better withstand the shock of snow plow service, a PTO cover and drive gear, and an extra bearing to support the thrust to the main shaft created by a PTO adapter.
ram 2500
12-08-2008 08:07 AM
