Heat shield template
Re:Heat shield template
Print each page out on 8.5 x 11 and tape them together. Vegasbound gave me a great tip. He told me to cut it out of a piece of cardboard and use that to position it. Once you got it where you want it, press down on the airbox mounting studs to punch holes in the cardboard. Then use the cardboard as a template to cut the final heatshield. Worked great.
On the same note, here's what I did.
I drilled 3/4 inch holes in the heatshield that lined up with the factory box studs.
Pulled the rubber grommets and torx nuts out of the factory box, and pushed them into the holes in the heatshield.
Holds the heatshield down nicely.
Here's a link to my install thread if it helps any.
https://www.dieseltruckresource.com/...7023#msg157023
Two part thread, bumper then BHAF.
phox
phox
I could not print or down load the template could some one email me a copy taken5875@cs.com thanks
