Heads Coming Off
Heads Coming Off
I'm pulling the head off my 96 I blew the H gasket a week or so ago anyway just trying to figure out what I need to do to keep it together and not be in the same boat 100 mile down the road with my mods what can i reliably get by with thanks ya all have been a big help I definately need with my ole beaters
With that kind of timing and a little extra air im not surprised it popped. Yikes!
Id do the head gasket, studs and o-rings. Maybe even consider getting a new loaded head with it already done, like from pure diesel power. Pretty cheap.
Have a machinist check for flatness and finish. Youll want as smooth a surface as you can get and it should be perfectly flat.
If you go to another turbo like a ps62 or 64 you can lower the timing and still get decent temps on the top end with those mods.
My headgasket is probably going to pop.. if I find a decent pump to install Ill have it timed to 16.5.
maybe a phat shaft 62/12 or something smaller that spools quick. Add a bit more fuel with something like large DV's and injectors you could try one a little larger.
I think at 4k on the governor 60lb valve springs are a good idea too, so you dont float a valve. Pretty sure its 4k and up.
Is this on an auto or a manual? Have you built the transmission / clutch to handle the extra power? Running gauges? a stock truck can kill a stock auto easy.. even the 160hp version.
snowmanx
06-10-2010 04:29 PM
