headlight wiring harness
If you are talking about going to relays, here are a couple.
http://www.rowand.net/shop/tech/Wiri...ightRelays.htm
http://www.danielsternlighting.com/t...ys/relays.html
http://www.madelectrical.com/electri...adlights.shtml
Floyd
Floyd
Thats supposed to be www.lmctruck.com
And unless they have changed it (which I doubt) there are better harnesses available from different suppliers. ^^ look up ^^ OR look down....
I ordered the wiring harness from Daniel Stern last week. Patiently waiting for it's arrival. I did a lot of e-mailing back and forth with Daniel before I made the purchase. He seems really up to speed on the whole Dodge lighting issues and calls a spade a dirty effen shovel. I kinda like the guy! Will keep ya posted when I get the harness installed.
Cheers!
Mike
Cheers!
Mike
http://www.turbodieselregister.com/f...sion-done.html
I was thinking this one
http://suvlights.com/product_info.php?products_id=112
Don't want to convert to sport lights if I don't have to. Just want to upgrade harness. I can convert to 9007 bulbs later on
I've got the LMC harness. My only problem with it is that I had to add some length to the wiring so I could safely route it on top of the radiator. I don't remeber the exact wire guage but it was 12 or 14. The light output is a good improvement over stock.
I dont know the guage offhand but there is no way the LMC harness has 12 guage wiring. Its cheaply made, you have to extend the wiring to make it reach the other headlight and the relays are junky. My passenger side light doenst always come on or shuot off due to a bad relay. Like I said before there are much better harnesses available.
