Headlight upgrade
Old 12-11-2012 | 02:07 AM
Ramitt's Avatar
I run anzo quad projector lights with hid's. My old dakota had hid's in them and when I got my ram the stock halogens werent cutting it at all. My hid fog lights are brighter than my halogen high beams were.
Old 12-11-2012 | 02:09 AM
Doj Dewd's Avatar
OP -
Stay away from eBay junk … I too got sucked in, and they sucked, but looked fancy!
I have since upgraded to the sport lights, with a homemade, heavy-duty conversion harness, as well as high output bulbs. With high beams on, and i use my driving lights (4" x2 100w each) - I can barely tell the auxiliary lights are on!
Old 12-11-2012 | 07:54 PM
NE frmhnd's Avatar
Originally Posted by Flatbed24v
Thanks for the replies, is there any plug and play solution with out having to rewire anything? Such as spec-d black crystal headlight housing with brighter bulbs? That happens to be the ones that i like so far but not sure how they fit/perform.
There's a couple sets of instructions in the first-gen board's "sticky" about how to run your headlights off relays, and it can be done without hacking your stock wiring.
Old 12-12-2012 | 08:37 AM
Tim9712v's Avatar
Once I get my truck back from the paint shop I will likely get a set of these:
http://www.ebay.com/itm/150792116816...84.m1423.l2649
anyone have any experience? Good, Bad, ugly?
Old 12-12-2012 | 09:33 PM
NE frmhnd's Avatar
I think I would toss the conversion harness, and do the relay mod, and run all 4 bulbs on high. If a hi/low bulb will fit in them I would consider running all 4 on low as well.
Old 12-13-2012 | 11:54 AM
Doj Dewd's Avatar
DON'T RUN ALL FOUR BULBS ON LOWBEAM!
I tried this long ago as I built my harness to do this by using a 5 pin relay instead of 4 pin.
Anyway, the four bulbs put out a lot of light and it seemed great … until I hit some heavy fog, and the inner bulb was horribly aimed with lows, resulting in REDUCED visibility.
Old 12-13-2012 | 12:40 PM
Ramitt's Avatar
Could run a separate switch to kill the other lights when running lows that way like you said if you hit heavy fog you could just turn it off and use the normal lows. Then flip the switch on and it works with the other lights(kinda like how a plow is set up)
Old 12-13-2012 | 03:08 PM
Silver R/T's Avatar
I'd run some anzo projectors
http://www.ebay.com/itm/Anzo-Headlig...ac92b3&vxp=mtr
Old 12-13-2012 | 03:54 PM
Dane's Avatar
One thing to remember if you just run higher watt bulbs in the stock headlamps - The dash headlight switch is not designed to run anything higher than 60 watt, so make sure to add a relay if you stick in a 55/100 Hella or other aftermarket bulbs. I had the Hella 55/100s collecting dust in a box and decided to retire the 11 year old PIAA 55/60 super whites. Interestingly the 11 year old bulbs were showing their age when I removed them. I could see some "sag" in the fillament wires and etching of the support wires.
Old 12-14-2012 | 05:30 PM
Doj Dewd's Avatar
Yes but this doesn't solve the problem of the beams aimed too high. If they hinder vision in fog because they aim high, then they are likely hindering oncoming drivers too.
The sport lights have NO provisions for using the inner bulbs low beam filament. The inner reflector is designed purposefully for the high beam filament only. The outer reflector is designed for low and high beam use, with each respectful filament.
Old 12-14-2012 | 11:37 PM
joem's Avatar
Here is the long lost Thread everyone needs to read:
https://www.dieseltruckresource.com/...t-t260623.html
Old 12-14-2012 | 11:43 PM
joem's Avatar
Correct Ram sport lights:
http://headlightsdepot.com/products/...5/CS163-B001PH
Correct easy to install relay kit:
http://www.genosgarage.com/BRITE-BOX...fo/BB_4_2_7_4/
Old 12-15-2012 | 11:55 AM
blackimpala's Avatar
Amazon
Originally Posted by joem
I got the same system from Amazon for less than the price on this site. But that was about a year ago.
Floyd
mtdoragary
11-07-2013 09:31 AM
chuxtruk
06-13-2007 11:31 PM
drakebuster
14
08-10-2006 06:21 PM
scarecrow
12-19-2005 11:28 AM
jlipskoc
10-24-2005 02:16 PM
