Head studs
Head studs
Has anyone ever tried to replace their stock head bolts on a motor with a perfectly good head gasket by removing them and replacing them one at a time? Do you think this is possible without disturbing the seal?
Also would replacing head bolts with studs and running a standard head gasket increase the holding capacity of the gasket enough to support a significant amount more boost?(assuming that you were to torque them beyond stock settings)
Originally posted by jlipskoc
Do the ARP 12mm or 14mm fit the stock bolts?
Also whats the cost estimate?
Can a person with basic mechanic skills do this, and if so are there any downsides, or quirks associated with this, ie. special tools other than standard basic mech tools and torque wrench?
So just remove the valve cover, and there right there?
(I have my hx40 wastegated at 40, but somedays I'm just wondering if she'll blow and need to do something soon like this, as removing the entire head for -ring/stud might be over my head)
Thanks Don.
John
Thanks Don.
John
I would consider it only requiring basic mechanical skills. You will have to loosen the rocker arm hold down bolts (recommended torque is 27ft lbs when you tighten them back up), so that you can get to the row on the intake side. Some people say you can get by without doing a valve adjustment, but I figured now was a good time to adjust them anyway.
IMHO putting in studs is easier then installing injectors, and neither is very hard.
Paul
Do the studs require a loosen and retorque? We just did my headgasket today for the second time in two days(don't ask, bad story) and my mechanic buddy helping do it said on John Deere they say to torque and let set over night and then loosen and retorque once more. They used to require a warm motor on retorque but did away with those specs. We're going to do a cold retorque in the morning just to see if there is any movement.
Torque them to spec and bring engine to temp and retorque they should move a little then run valves again. I suggest haisley or scheids studs they are the same studi have never blown a head gasket with them.
Paul
I'm pretty sure ARP doesn't make a 14mm stud for our trucks, so you'll get a 12mm stud if you order the ARPs.
jlh
I torqued them to 125, ran the engine (babying it the whole way little or no boost) to bring it up to temp. Let is sit over night then retorqued (on a cold engine) w/o loosening the studs and re adjusted the valves.
My truck is seeing 60psi every day with out any problems. (i say that beating my head on my wooden desk)
Justin
Originally posted by RDLeader
Come on Justin, crank that boost up to 80 or so.......Them fire rings will hold
Roman
Roman
I need to quit being a chicken and throw in the 55 lpm sticks.
But.....
I am happy with the pereformance and fuel mileage I have been getting right now.
Justin
