head studs
The Guru
How good is your current head gasket? Been running lots of egt's? If everything is in good shape and you torque the studs to 135 ft*lbs, you should be ok to 50+psi. Some guys get higher boost numbers. Head gasket don't like high drive pressure and high egt's. Studs allow you to abuse the head gasket more than the stock bolts. Bucks down, you could just crank-up the torque on the stock bolts.
How are you planning on putting them in?
12valvetom
11-27-2009 11:37 PM
dieselboy59
01-30-2009 03:57 PM
smokewagon
08-08-2008 09:54 PM
MikeThomas
05-11-2008 11:39 AM
jmccart
21
05-14-2007 11:47 AM
