Head studs
Bluedually4X4:
Yes Sir, it is alright to pull the stock bolts one at a time AND IN ORDER, and then replace them with the new studs as per the recommendations the Members have given here.
John_P
They way we do them if it's the stock Head gasket and not o rings and you plan on doing them 1 at a time. Is remove one, put in the new one all the way down till it stops, back off 1/4-1/2 turn. Put lots of ARP lube on the threads and top and bottom of washer. Take it right to 110lbs. And do all of them 1 at a time. Once their all swaped out go around and hit them all to 125lbs starting from the center out. Might have to grind a little of the valve cover in on the front 2 studs if you dont bottom tap the threads.
Brett
Brett
thanks
jason
12valvetom
11-27-2009 11:37 PM
dieselboy59
01-30-2009 03:57 PM
smokewagon
08-08-2008 09:54 PM
MikeThomas
05-11-2008 11:39 AM
jmccart
21
05-14-2007 11:47 AM
