Head ?'s
Orings typically cost $50/hole. The problem is finding someone close with the correct plate that bolts to your head or block for the cutting. You may want to consider an aftermarket head that's already oringed and ported. Then you could swap heads and be done.
brandon.
brandon.
Originally Posted by blackdiesel02
thats the problem, theres not. i have to go about an hour north to get a shop. and im not really even sure if its any good. Anybody know a shop around Northern Arkansas?
http://www.scheiddiesel.com/Contact.htm
Originally Posted by Tiger Rag
I'm sure you'll hear me crow if I break the 500 hp barrier.....'course I should be there already with the Mach 6's I've got in there now....we'll see what the the dyno says though.
Later, Matt
Later, Matt
brandon.
brandon.
i havent found a place to o ring it yet. if i can get it done locally for a reasonable amound of $$$ i'll get the block done too. so i just need a shop to do the machine work
Doug Smith
to get my head and block o ringed would cost 600 bucks? can i just do the head and push 65 safe boost psi?
Paul
Also need to check to make sure the head is flat...and have it checked for cracks. Piers always said that there will be cracks..it just depends on how many and how bad they are.
That would be the first thing that I could do..is have it check for cracks. Not good to spend the money on O ring and then find out the head is bad...
Rick
Rick
Originally Posted by Jetpilot
If you want give us a call and I can help give specs to a machine shop in your area.... Its not magic, if they have a good mill they should be able to o-ring it for you.
Doug Smith
Doug Smith
Well..... ARP is still in production with them. Hopefully they will arrive in the next 4 weeks. The clamping force should be quite a bit higher so there will be better integrity.
As for the holding limit, it has to do with cylinder pressure more than boost pressure. When we alter timing, nitrous, propane, water/meth, all of these change cylinder pressures as well as boost. These studs are designed to give the clmping load of 14mm studs without the detrimental effects of removong block material and reduce the cost associated with it.
Doug Smith
Doug Smith
Conn
12-29-2006 06:30 AM
Dusty Ratcliff
04-10-2006 07:35 AM
OT-OF-Here
08-07-2004 07:56 PM
