Head Removed for Headgasket repair, cylinder pics
Old 02-13-2007 | 11:00 AM
  #46
Bobcat698's Avatar
Originally Posted by PourinDiesel
Garrett,
Of the 20w50's I know dont have the soot additives that are part of most diesel oil's out there. But there might be some that do have the additive package.
So basically if you run the 20w50 without the additive package I would change it on a real regular basis IE every 2000 miles or so.
Last year I was changing my 15w40 oil every 1500 miles or so during pulling season.
This year I am going to try some 20w50 during pulling season since my motor is starting to loosen up a bit!
So on a non street driven truck, every 3rd or 4th pull?
Old 02-13-2007 | 12:39 PM
  #47
PourinDiesel's Avatar
Garrett,
Really you just have to judge for yourself on the oil thing.
Since the common rails soot the fuel up fast I wait for the oil to start having a burnt smell to it before I change it during sledpulling season.
Old 02-13-2007 | 03:52 PM
  #48
mysterync's Avatar
this is a great update, im curious to see too! Considering i've been running high egts but i dont drive the truck much so no worries! Bobcat did you see that thread with those pics you asked for ? There also on my site!
Old 02-13-2007 | 04:34 PM
  #49
Bobcat698's Avatar
Sorry, I'm lost.. Where did I ask for pics?
Thanks
Old 02-13-2007 | 07:56 PM
  #50
mysterync's Avatar
new lights, ill pm ya
Old 02-13-2007 | 09:09 PM
  #51
Bobcat698's Avatar
Originally Posted by Mcmopar
What kind of a stand are you using to hold this up?
A 2000lb engine stand I found
I figure can't go wrong with the price, we'll see if its any good.
Only $10 shipping No one has anything locally...
Old 02-13-2007 | 11:16 PM
  #52
Munchies's Avatar
Theres a guy in flagstaff az rebuilding cummins for 2k. head and long block I believe. I would pull it, and R&R the bearings, go the next size over, rings, blah blah.
Old 02-14-2007 | 08:27 AM
  #53
Mcmopar's Avatar
Where did you find it?
Old 02-14-2007 | 08:34 AM
  #54
signature600's Avatar
Garrett,
A CR soots the oil worse than a 12v?? I would think that's backwards!
Chris
Old 02-14-2007 | 09:07 AM
  #55
RowJ's Avatar
Originally Posted by HOHN
FYI-- redline Oil has a flashpoint 486° in their diesel 15w-40.
Royal purple is 435°
Redline is overkill for most guys, but if you are pushing the limits and abusing your truck, that extra high flashpoint may prevent the scoring seen above....
IMO either flash point is excellent... and more than enough for the Cummins. Even under the most extreme uses I have never seen oil temps over 240-250*F. A lower flash point would affect the oxidation rate of a oil, and therefore how often it needs changing, but should not be a major concern for those pulling or racing.
I would tend to put more emphasis on % by wt. of Zinc in the additives. Most national brands add very little Zinc. It is essential, IMO for high performance applications.
However, Higher Flash Points do tend to indicate a better quality oil....with better base oils and better additive packages, which do make a big difference in protection of moving parts.
RJ
Old 02-14-2007 | 09:10 AM
  #56
Bobcat698's Avatar
Sorry original post didn't work.
Found it here
Old 02-14-2007 | 10:14 AM
  #57
Don M's Avatar
DTR Advertiser
Yes, Rowland MPZ contains high levels of zinc.
I just went and tasted a tube of cam lube
Old 02-14-2007 | 10:25 AM
  #58
RowJ's Avatar
Breakfast is the most important meal of the day.
Found the info on MPZ... looks like good stuff!
RJ
Old 02-14-2007 | 11:23 AM
  #59
BlueDually's Avatar
What would you guys call adequate for a oil flash point, I just looked up my 0-40 esso/exxon oil and its "224 C." Seems low compared to to redline 486 and the rp 435.
Old 02-14-2007 | 11:39 AM
  #60
RowJ's Avatar
We were talking degrees F.
224*C is 430 *F. (+/- 5 degrees) .
As long as operating oil temps are NOT within 100*F of Flash Point.... I would be satisfied.... so say 350* Flash or above.... as long as it meets CI-4 diesel rating.
RJ
Quick Reply: Head Removed for Headgasket repair, cylinder pics
