head gasket? studs? need help
hello all, im currently building my newly aquired 95 12v and had some questions. im going to o-ring the head and stud it, but i don't know which stud kit to go with here are a few i've seen, A1 12mm, ARP 12mm, and haisley 12mm, which is the best? also what head gasket should i use, i plan on twins in the future, since im o-ringing the head is there a certin head gasket to use? thankyou for any help.
jason
jason
The Guru
The arp's are good choice. How much boost your gonna run? If your gonna exceed 70psi, run a copper head gasket. How much advance you running? If you run lots of advance, go the copper head gasket. The bad side of the copper gasket is that they slightly leak coolant and are a bit messy. I'm running a stock 2gen gasket but I hardly exceed 65psi of boost.
well for a single turbo i probably won't pass 45psi, but my future twn set up i plan on pushin 70-80psi, right know the 95 12v is out of the truck and is stock so i haven't messed with the timing yet, also i have heard about using a marine haed gasket, are they good for 70psi?, and where can i buy a copper head gasket? should the haed gasket be a bit oversized, like .10 over? sorry about all the questions, but i don't want to build this engine twice. thanks again for the help
jason
jason
I like the 12mm ARP studs and the marine headgasket using o-rings. This setup holds very reliably to over 80 psi. On my old truck I saw over 100 psi on this setup with no failure. The trick is to do the o-rings correct and spend the time torquing the head. Done correct this is about the ultimate street setup. The A1 and Haisley studs are the same.....
Doug Smith
Doug Smith
well i appreciate all of your opinions and will probably go with the marine head gasket, since the copper ones have more of a tendency to leak, but where can i buy a marine head gasket and should i get it a size larger, like .10 over?
jason
jason
And the ARP studs are on sale over at www.naparts.com right now
So if you use a thicker head gasket (.020) and you only have to remove .007 off the head to true it up, that makes the head sit .012" higher than stock. Do you have to re-shim your injectors to adjust for the change in location? Does that cause any issues with compression?
In general terms, how does a bombed ctd respond to lower compression of a .020 gasket?
The Guru
My truck has difficulty starting at cold ambient (below -20) when not plugged in. Sounds like only three cylinder are running. Tons and tons of smoke. I've heard that dropping the cylinder pressure abit helps with cold start but it might be a tall tale.
We use only the .020 over gaskets on all headwork/rebuilds we do. The compression drop is small and the plus side is improved valve to piston clearance. There isn't any cold weather start problems either.
Doug
Doug
pwrtripls1
03-10-2011 12:12 PM
12valvetom
11-27-2009 11:37 PM
dieselboy59
01-30-2009 03:57 PM
smokewagon
08-08-2008 09:54 PM
SmokenRam
13
02-19-2006 06:35 PM
