Head Gasket GONE!!!
Old 01-17-2007, 01:33 PM
  #31
BigBlue's Avatar
If ya ain't popped it then you should be fine. Definately worth checking on though.
Old 01-17-2007, 01:50 PM
  #32
Dshiftff's Avatar
Originally Posted by BigBlue
Nothing a dremel can't fix.
Other way around. Nothing a little RTV cant fix lol
Old 01-17-2007, 02:18 PM
  #33
Diesel-Dan's Avatar
HUH....so the 3rd Gen gaskets won’t work.......i could have sworn i hear that they could from a very reputable source......HUH….o well…good to know I guess……I just don’t want to o-ring……
Old 01-17-2007, 03:13 PM
  #34
Dshiftff's Avatar
Dan heres the guy who tried it. http://www.turbodieselregister.com/f...d.php?t=174667
Old 01-17-2007, 04:19 PM
  #35
Diesel-Dan's Avatar
Interesting.......But he did say 12V. Same hold true for a 24V VP Engine?
Quote from the link for thoes that dont have TDR.....
Originally Posted by JTEdieselram over at TDR
OK OK OK, so I have been swearing up and down that this thing will work in a 12v (looks identical, and installs without any trouble) great choice because it is MLS construction. Well.........It does not work. there is a small oil passage (on the pressure side) that pukes oil into one of the water jackets. Nothing like putting your truck back together and running it for like 30 seconds and getting a radiator full of oil and a pan full of water needless to say I was ******......But at least we all know for FACT that the MLS gasket from a new HO will NOT work, I tried to come up with somthing that I thought would be revolutionary to the 12v sceen, but I guess we will have to wait for someone other than cummins to manufacture a MLS gasket for the 12v. Until then, I guess O-rings will have to do. Please spread this info and save others the hassel! I will have a write up on my truck soon including the HO gasket whoes!
Old 01-18-2007, 01:39 AM
  #36
98.5POS's Avatar
Retorqued the head to 125 lbs tonight to see if the problem would go away, well, it didn't. All the studs were still at 96 lbs like we left them. Pulled the head and the compression took out the front part of the gasket. Put a straight edge on the head and couldn't get even the smallest feeler guage under it, I'll check the block in the mourning.
Talked to Doug at PDW about their Marine HG, he suggested that I go with o rings. Maybe I will. It's late, see ya'll.
Old 01-18-2007, 09:58 AM
  #37
Dshiftff's Avatar
the 12 valve gasket works on the 24 valve, you just need to enlarge a few existing holes. They are the gaskets many 24 v guys use when they install a firering setup.
mhuppertz
01-23-2013 01:25 PM
cbrahs
11-01-2011 11:00 AM
roxxx
09-24-2009 08:17 PM
wildchild97
09-25-2007 02:44 PM
darrenG
07-13-2006 03:48 PM
Quick Reply: Head Gasket GONE!!!
