Head Gasket
Head Gasket
Can someone please tell me at what HP level the stock head gasket is ready to be kicked out? My truck is mainly used for dragging a 5th wheel around. I would never here the end of it from my better half if we broke down due to a head gasket failure (not to mention the cost of having to tow the truck and 5'er in for a repair). In my case reliabilty is KEY!<br><br>513 HP & 1140 TQ
Re:Head Gasket
My first one let loose at about 400hp, (no drugs either) which is well below your 513. However when I replaced it, I torqued it to 130#, instead of the factorys 75#'s and 1/4 turn. Now I'm up near/at/or above 500hp and 50+ psi boost, and still goin' strong. Next spring it WILL be o-ringed for sure though.<br><br>Later, Rob
Re:Head Gasket
Rob, How much timing were you running at the first failure you had? I'm at 16* and thinking hard about o-ringing the head this winter. I hate surprises while on the road.
Re:Head Gasket
Dunno, I had the comp box off , or real low, I can't really remember where the darn thing was, I assume your a 12v? You may want to check around to see if the what I said above works for 12v's also, I'm not sure.<br><br>Later, Rob
ted_pulliam
07-16-2009 12:33 PM
wildchild97
09-25-2007 03:44 PM
Conn
12-29-2006 07:30 AM
