HE351ve swap to 12 valve
Old 05-27-2016 | 03:12 AM
LanceD's Avatar
Picked up a 6.7 turbo from a member on here for my 12 valve. I'm open to any hints or tips for the swap. I plan on using a Steed stand alone controller for it. I tapped the coolant lines to npt threads for more common fittings. I see the mounting flange is different, should I get an eBay adapter plate for it? Or get a new manifold with the correct flange? Also what about the exhaust? Who sells exhaust parts to piece together a 5 inch kit? I don't need the rear section. Will my oem oil feed and drain bolt up to it? I'll probably need a new tube to the inter cooler as well. I'll be sure to post pics in this thread.
Old 05-28-2016 | 02:15 AM
LanceD's Avatar
Here's the turbo, polished up and painted the cover, removed the little pins so I can clock it. Also tapped the coolant ports to npt threads.
1972RedNeck
12-30-2013 10:16 AM
SKATERHAULER
12-05-2013 07:40 PM
cj360trider
32
04-18-2012 07:54 PM
evil06sti
19
01-07-2011 12:07 PM
oly_fab
04-13-2009 09:44 AM
