HE351 on 12 valve
Hy35 on 12 valve
I have a HY35 and am wondering if there is some advantages to using this on my truck. I only have a 3gsk and a 10 plate a little forward right now but I'm thinking of some injectors and timing soon. And that will be as much as I intend to do. I'd like to know about this because I don't want to spend $1000. I've read the few posts I can find, so know about the 9cm2 exhaust etc. I'd like to hear from anyone who has actually tried this, more interested in experience than theory.
HE351 is what the HPCRs use from '04.5+ (not the 6.7L AFAIK)
Best 'charger (not counting the VGTs) that Dodge ever put on a Cummins IMO!
Spools quick, flows plenty of air, still makes power at 45+psi, takes a lot of heat & abuse.
Price is right too! - you can pick them up for a buck fifty on ebay...
we're putting a pair on the '98 this winter.
Here you go. you need to know if its a HY35W type D or a HE351. there is a diff. You can just select each and see what you have.
http://www.holset.co.uk/files/4_4_1-...%20manuals.php
Thanks 1stGen. It is a HY35D. It seems to me that this turbo should spool up quicker which would be nice. I'm just wondering about higher in the rpm range and egt's.
ZacMan5712
12-19-2008 09:29 AM
Big Blue24
11-27-2008 12:36 PM
PaulDaisy
19
10-08-2008 12:05 PM
