Have you ever broke a billet input shaft?
Old 02-12-2008 | 01:50 PM
Ram_SRT-10's Avatar
just as the title says have you ever broke a billet input shaft?
Old 02-12-2008 | 01:55 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I know of several that broke...
No such thing as "unbreakable" You say that to some of the guys around here and they will go out of their way to prove they can break it
Old 02-12-2008 | 02:02 PM
Clayten's Avatar
DTR's Toad Wrangler
Ya what Lary says nothing is unbreakable. Just ask any one that has been a welder or mechanic in the oil field, those fellas put a new meaning to broken.
Old 02-12-2008 | 02:38 PM
dzlfarmboy's Avatar
I've broken a billet output, but Opie has designed an input shaft that is physically larger in diameter then the standard billet shafts. And you have to run his converter cause the hub inside of it has to be larger to accept the larger shaft.
Brett
Old 02-12-2008 | 02:51 PM
EBunger's Avatar
I broke an ATS 2 piece last year. Not only that but the other shafts in the trans are stock!
Old 02-12-2008 | 11:39 PM
timbeaux38's Avatar
They all break... Leave too hard too often, or screw up with a lock-up switch and you will bust one eventually.
Old 02-13-2008 | 04:28 PM
12valvetom's Avatar
now that really says something about ats
Old 02-13-2008 | 10:01 PM
Charlie8301's Avatar
I broke a billet input this summer. Locked it in 2nd gear under full load
Randy
Old 02-14-2008 | 05:09 AM
LanceD's Avatar
the new trans I ordered has the Sonnax 1 piece 300M billet input, hopefully I won't break that
nrussell
25
01-03-2009 08:46 AM
jjj_85
04-24-2008 12:00 AM
DMS1707
03-15-2007 12:32 PM
blackcloud
06-15-2005 10:13 PM
4x4
22
04-08-2004 04:40 PM
